Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Toshiba 42H82 the screen will go black after 5 minutes, sometimes it comes back on after a minute, but most of the time I have to turn it off for about 10-20 minutes. Some days it works fine, others it will have a black screen or a 1 inch wide arc across the center of the screen
Posted by David Wical on
Ginko
  • Toshiba Master
  • 19,396 Answers
Hi.
It is probably a defective ballast board or a faulty PSU. The ballast is the high voltage power board connected to the lamp.The PSU is the board that supplies power in different voltages to the other internal parts. One of the DC lines from PSU goes straight to the ballast. The repair is done testing the voltage from PSU to ballast. The job must be done by a technician.
Posted on Dec 15, 2011
My toshiba rear projection TV's picture just went black. Sound is good just a black screen.
high voltage is not coming up. possible fuse locates on power supply board on the right if you are sitting behind set with back off. if fuses are good, possible horizontal output transistor shorted. sounds horrible but easy repair
Nov 10, 2009 | Toshiba 42H82 42" Rear Projection...
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
Toshiba Picture Not On
what you suggesting is that the lcd has a good maintenance needs that have to have cold solder or connectors are sulfated
Aug 22, 2009 | Televison & Video
The TV cuts off frequently. The screen is blank & no sound.
It is probable you have a poor soldered connection on the power supply board, hence the erratic timing of the TV going on & off. If you are competent with a soldering iron look for dry jointed soldering on the board. If not have a service engineer take a look at it for you.
Jun 24, 2009 | Panasonic Televison & Video
Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Jun 16, 2009 | Toshiba 46HM95 46" HDTV
Trinitron kv-32FS100 Black screen periodically, with sound, light blinks 5 times
5 blinks means there is a short in hor.section or the power supply
about 200.00 --- 250.00
Jul 12, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
LTV-27w7 blackscreen
Have you tried unplugging overnight? Sometimes mine gets screen garbage and that clears it up. Of course, now it says "Auto Scan Required" every time I power up. Maybe I should've grabbed that after Xmas 32" at Fry's for $400.
Dec 25, 2007 | Westinghouse LTV-27w7 7 in. LCD HDTV
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
Half black screen on projection tv
Sounds like the vertical area like Output, but I would look for bad caps first and resistors. In this area
Sep 14, 2007 | Televison & Video
Screen tuns black after 15 seconds and comes back after about 15 minuts
The solder joints on the vertical output IC have cracked. This is a very common problem on those sets.
Nov 14, 2006 | Panasonic CT-27G34 27" TV
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
