Connecting pvr dstv decoder 3001 - Televison & Video
Posted by nicholas on
Solyana
    New Friend:
My pvr decoder model 3001 remote control doesn't work I checked battrey it works but no answer for decoder what shall I do
Posted on Mar 16, 2012
2 Related Answers
kukere
SOURCE: no signal from dstv decoder
no signal for dstv for my decorder pls help me.
Posted on Mar 20, 2011
Anthony Cahill
  • 102 Answers
SOURCE: We are installing our new Toshiba flat screen TV.
Make sure you are on the correct input on the TV, I.e select Scart if you are using a scart lead and HDMI if your using a HDMI lead. If you have confirmed this to be corrct then you may have a defective cable or worse case senario a faulty port on the tv depending on the cable you are using.
Posted on Mar 24, 2011
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
I'm not able to connect my dstv decoder and dvd player onto my samsung 51"plasma tv because there's only one AV plug. Can you please help?
  • i cant connect my standard decoder to samsung 51inch as ther are only ports compements and hmdi,do i need a pvr decodr?
Jul 12, 2011 | Televison & Video
We are installing our new Toshiba flat screen TV. We have a DSTV PVR decoder. We get "no signal". What should we do?
Mar 24, 2011 | Toshiba 19HLV87 19 in. LCD HDTV
Printer Setup & Support Call 1-(805) 225-6690 We are 24 Hour Available Call Now For Help
how can i have codes to tune east african channels plis for free. am using dsd 1131 decoder of dstv. am in johannesburg.
Jun 18, 2010 | Televison & Video
Need to connect my DSTV decoder through my sony amplifier (5.1) not sure of a the cabling or the connections, does someone perhaps ahve a wiring diagram to connect TV, dstv decoder and sony 5.1 amplifier?...
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
Jun 29, 2009 | Fujitsu Siemens PlasmaVision P42VHA40...
Televison & Video Logo
505 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
