Question about Kwikset UltraMax Powerbolt 1000
Replaced batteries, now I am getting 3 sets of 2 loud beeps everytime I unlock the door with either code. Also the green light is continuously blinking.
The batteries were getting low after about 1 year installed. I made the mistake of waiting too long with my first Kwikset lock, and it crashed the electronics. I had to purchase a new unit.
Posted by Pat Feathers on
  • Pat Feathers Mar 11, 2012
    I followed all the directions above several times. The beeping stopped, but now we have to punch the code in twice to get the bolt to turn far enough to unlock. (it gives a pathetic whine as it turns), but the lock button works with one push. I can't keep spending $100 per year for a front door lock, so my next one will be another brand.
  • Coaltowner Mar 11, 2012
    The Powerbolt is manufactured (for/by?) Black & Decker, under the subsidiaries Kwikset and Weiser Lock. In the past year and a half or so that I've been answering digital lock problems, by far I've seen the vast majority are problems with the Powerbolt. Now, I can't say if it's because there are so many more Powerbolts out there than any other brand or if they just tend to be more problematic than the other brands. But if asked, I would not recommend them to anyone, based on the sheer number of problems that I've seen with them. Try a Schlage lock next time.
Coaltowner
  • 963 Answers
The troubleshooting instructions (link here)
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HifLAAS.aspx
will tell you that you will get a series of quick beeps when the batteries are installed correctly and making good contact.Conversely, the low battery indicator light on the power board will be lit when the batteries need replacement. Kwikset recommends that you use four quality alkaline AA batteries.
Also, Kwikset recommends that if your Powerbolt is beeping, that you take out the batteries and remove the powerstrip. Let it sit for one minute, then put the batteries back in and wait for another minute. If it does not beep, as in above for battery replacement, then the keypad needs to be replaced. If the unit beeps, then the powerboard needs to be replaced.
Is it at all possible that, when you replaced the batteries, you did not get the orientation correct for one or more of the batteries? Did you use new, brand-name alkaline batteries?
So, I've taken you through the steps that a Customer Service Rep is going to ask you before you make a call. If the problem still persists, then it's time to make that call. The number is 800 327-5625, Mon.-Sat. between 7:30-4:00. Pacific coast time. They should be able to assist you further with troubleshooting and parts.
Good luck-and please provide feedback if this helps!
Posted on Dec 15, 2011
How to change code N15115
Input the new code (1-8 digits then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again Emergency Key - store in secure place NOT inside the safe. To ensure the batteries have been installed correctly test before closing the door. 2 bolt locking mechanism, opens with a digital code or emergency key. Floor or wall mountable, immediately locks out after 3 invalid code attempts. Durable steel construction, model Name 24/7 Digital Safe, material, galvanised steel. Opening the safe a. Pre-set factory code 159 b. Input 159 (the yellow light will flash and the buzzer will beep then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened Closing the safe: close the door, input the code (the green light.
Feb 01, 2015 | Home Security
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
1) After unlocking door unit emits 2 beeps 4 times? 2) Green LED in door continually flashes?
remove all batteries, wait about 10 seconds then install new ones, one at a time, I found this clears the flashing
Mar 24, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Samsung digimax s500/cyber530 won't start with new batteries
I have a samsung digital camera digimax cyber 530 - just replaced batteries and camera wont start, i get 3 flashes from the green light screen nw comes on then goes off & the lens wont retrack back in the camera
Oct 20, 2009 | Cameras
Random beeps
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
-=dån=-
Jun 22, 2009 | Weiser Lock Powerbolt 1000 Lock
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
Car won't start
Hi, does the alarm shut off when you unlock the passenger door?
If it does not I will give you a test that you can do.
1. disconnect the harness anti-theft control module. (loctaion depend were you live USA next to fuse panel Canadian models above the glove box.) Check the continuity between Light Green/Black wire and Black wire of the anti-theft control module.
2. Continuity should not be there with the door lock in, lock or neutral position. With the door lock in-between lock and neutral position (any door) continuity should be present.
3. If continuity is as specified replace the anti-theft control module. If continuity is not as specified, check operation of the door lock switches.I will add that test at bottom.
4. If the door lock switches are ok check the continuity og LIGHT/BLACK wires between anti-theft control module and door lock switches. Check Continuity of BLACK wire between door lock switches and ground. Continuity should be present if Continuity is not present repair harness or connectors.
5. If Continuity is present, check continuity LIGHT GREEN and BLACK wire of anti-theft control module. Continuity should not be present with trunk lock in lock or neutral position. With trunk lock in-between lock and neutral position, Continuity should be present.
6. If Continuity is as specified replace anti-theft control module. If Continuity is not as specified, check operation of truck lock switches. If necessary replace trunk lock switch.
7. If trunk lock switch is ok, check Continuity og LIGHT GREEN wire between anti-theft control module and trunk lock switch. Check Continuity of BLACK wire between trunk lock switch and ground. Continuity should be present. If Continuity is not present repair harness or connectors.
DOOR LOCK SWITCHES
Disconnect 4-pin door lock switch connect (left and right front doors) With door lock in neutral, full lock or full unlock position, there should be no continuity between any terminal and BLACK wire terminal. Continuity should exist between LIGHT GREEN?WHITE wire and BLACK wire terminals with door lock in-between neutral and full lock position. Continuity should exist between LIGHT GREEN/BLACK wire and BLACK wire terminals with door lock in-between neutral and full unlock positions. If continuity is not as described, replaced door lock switch.
Hope this help its a place to start. let me know if you need anything else.
Cheers
Aug 23, 2008 | 1994 Nissan Maxima
Kwikset UltraMax Powerbolt 1000 Logo
1,082 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
