Question about Archos 7 HOME TABLET V2 8 GB Hard Drive
Cracked lcd screen - Archos 7 HOME TABLET V2 8 GB Hard Drive
Posted by david cochrane on
Joe2
    President:
  • 2,080 Answers
You can just replace the LCD screen itself if you want, assuming you have a set of micro tools and a bit of basic electronic repair skill.
Replacement screens are available online although they can be fairly expensive.
Here are a few links to replacement screens for your device currently available on EBay for about $59 US plus shipping:
http://www.ebay.com/itm/new-origial-ARCHOS-7-internet-Tablet-lcd-screen-display-/270871381153?pt=UK_CE_GPS_Accessories_Software_ET&hash=item3f113144a1
http://www.ebay.com/itm/new-origial-ARCHOS-7-Home-Tablet-lcd-screen-display-/270860700686?pt=UK_CE_GPS_Accessories_Software_ET&hash=item3f108e4c0e
Just use your mouse to click on the links, which are the underlined and blue highlighted sections of text just above.
This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Posted on Dec 14, 2011
MY TOSHIBA LCD TV SCREEN IS CRACKED DOES IT HAVE A
Hi Erika,
If your LCD is cracked, you will need to unfortunately replace the entire LCD. Simply putting a screen protector (which is just a thin film) will not stop the crack from getting worse. There is unfortunately no magical way to fix your screen other than simply replacing the LCD panel itself, which is totally doable. Many electronics repair shops can fix your TV pretty easily. In some cases, you can even mail it into Toshiba.
Oct 03, 2013 | Toshiba 32AV502U 31.5 in. LCD HDTV
Lcd tv screen crack
any crack in the screen will need replacing it weakens the screen and can shatter. also the picture don't look good. would change the screen.
Mar 26, 2013 | Coby TF-TV3217 32 in. LCD TV
What's your problem?lcd 32 in tv screen cracked but i can't feel the crack
This is the end of the set===screen is called a display panel and if available will cost more than a new set just for the part.
May 24, 2012 | Envision L32W761 32 in. LCD TV
The screen looks cracked and multi colored but the actual glass isnt broken or cracked
Your LCD/monitor is cracked from the inside. There are several things that can cause a screen to crack from the inside. The two most common are pressure on the screen or dropping the machine. Sorry, but it is irreparable. You need to buy a replacement.
Jun 15, 2011 | Computers & Internet
LG 42" tv LCD pannels inside tv have a cracked
The set needs a new LCD if it looks cracked and swirly, the colors all run together in the area of the crack don't they! If it is cracked it can't be fixed. you can replace the lcd but I am not sure if a warranty will cover a cracked screen or not. You will need to contact LG and be very nice to them and see if they will honer the warranty on this.
Jan 18, 2011 | LG 42LC2D 42 in. LCD HDTV
Broken screen on Blackberry Curve needs to be
you can use warranty or send it to the company and they will charge you if you hadnt taooken the warranty
Sep 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Large LCD cracked screen from impact, worth repair?
Cost alot to replace LCD screen not worth the money.If u can find it on Ebay bad PCB,and a
good LCD screen is might worth to repair.
Aug 23, 2009 | Televison & Video
I am not able to open my laptop, when I tried to open the screen it makes some noise as if something is getting crushed
If you are trying to disassemble the LCD screen and hear cracking sounds then - the crushing/cracking sound is most likely that you have cracked the LCD screen in several places. If you look at an acute angle you will see cracks in the LCD screen.
Replace screens are available at LCD Parts, they supply parts, repair service and DIY info. Use this link to their WEB site.
www.lcdparts.net
Jun 28, 2009 | Lenovo IdeaPad Y510 Notebook
I have a HP Pavillion TX 1000. Did everyone heard
It is highly improbable that heat from the CPU can crack a LCD screen. Even if the fan was faulty the CPU would have shutdown (thermal overload) before it would affect the LCD screen. If you apply pressure to the face of the LCD screen or twist the screen or impact the screen with a hard object, any of these will cause the LCD screen to crack.
Jun 11, 2009 | HP Pavilion tx1000z Notebook
Cracked ipod touch screen
£53 from these guys www.ukipodrepairs.co.uk
Aug 21, 2008 | Apple iPod touch
Archos 7 HOME TABLET V2 8 GB Hard Drive Logo
Top Archos Computers & Internet Experts
paulgbrandon
Relax
Relax
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
