Question about Moultrie I40xt I40xt Trail Camera 50 Mp
Moultrie i40 digital game camera will not flash
Posted by dpwpdw on
Ronald Lockhart
  • Moultrie Expert
  • 296 Answers
Run diagnostic test and cover sensors with thumb...may have to shade IR flash array to see it glow red...menu may start countdown...if flash doesn't glow you will get a 020000 error(flash/flash charging error).To fix you need to remove batteries,sd card,rubber plug from remote slot, 5 screws from face;lift out face and turn over. Remove 4 screws, keeping separate from other screws, from camera card and carefully unplug (3 plugin connectors) and carefully lift camera card out..no soldering required up to now..2 conductors,a red and a black, connect to the flash array at one corner...these go to the sensors on the face,slightly under main board...either the sensors are bad or the array is bad...getting replacements is the problem unless you can get them...I buy "as is" cams off eBay.
Posted on Dec 19, 2011
The screen has gone blank. It is still taking pictures.The camera is Moultrie game dgs-I40
www.moultriefeeders.com/support for new display with replacement instructions...not hard to replace.
Sep 26, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie I40 infrared not working
The ir gets power thru capacitors and inductors on main board.;check for loose connections, broker leeds; may have to replace ir array or main board to fix.Forget Moultrie having spares; try to buy used on as is from eBay.
Mar 26, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie I40 getting error code 480 and wont go into auto mode
ERROR CODE 000480 ?
If this is correct,it relates to: Camera Mod test failed;(4); and under Memory Test, 8= Comms Error.New batteries(good ones) may fix it...
It' not communicating with memory card..ck it's inserted good..press down until it stays down(press again and it will pop up.
Follow instructions on deleting internal memory before installing SDcard.
Also, make sure cam supports kind of card you're using..at 4gb and larger, they become confusing;i.e., 4/8/16mb...older cams won't support some of these. Also there are HC(high capacity); HD(high definition)don't work in these cams..
I posted this for a fix a few days ago, and it turned out to be brand new bad batteries.
Dec 23, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I40 night pics are all black. can see a branch at 2 feet but nothing else
The light bouncing back from the branch 2 feet away is shutting down the flash too soon.
Aug 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie gamespyi40 error code 020000
I just spoke to the moultrie techy about the same error message I have with my i40, This is a false positive message, the i40 uses infra red instead of a flash; the self test is testing for flash and giving the false error. This was an oversight by Moultrie, no down-loadable patches are available to correct this at this time
Joseph
[email protected]
Jan 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie I40xt I40xt Trail Camera 50 Mp Logo
237 people viewed this question
Top Moultrie Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a Moultrie Home Security Expert? Answer questions, earn points and help others
