Screen jumps between bright and dim
Have you checked the connections on your VGA cable
sounds like the cable is either on its way our or not getting a good connection make sure all screws are tight if this doesnt work might be worth borrowing a cable if you can before purchasing one just in case its the monitor that is dying
Testimonial: "Hey John, right you are, the second I touched the cable the screen became bright again. Thanks for your help!!!"
SOURCE: screen goes bright to dim and dim to bright
do you have the unit plugged in when this happens? there are different power settings when the unit is plugged in and when it is is just using the battery. You can adjust those settings in the user tools or or preferences. It will also do this when you are idle, the unit is just trying to save battery life.
