We have a Kenmore HE2 Plus front-load washer. When I tried to start it today, I could turn it on and adjust the dial, but I could not push any other buttons on the control panel (e.g. water temp, cancel). It acts normally like it's going to start the cycle- the door locked light comes on, the display shows the time length and there's a click like the water's going to start. Then it shuts completely off without flashing any error codes. What's wrong with it, and is there any chance we can fix this ourselves?
SOURCE: He3 Won't start - lock door or start water flow, although dispay works with no error
The door switch is damaged and needs to be replaced.
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Had this problem on our Kenmore machine.
This is what done.
1. Unplug the washer
2. Take of the toe panel in the front by removing the three screws.
3. Get a bunch of towels (I mean a bunch!!!)
4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
5. Clean the filter assembly.
6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
8. Remove the Torx screw that holds that is the center just under the filter screen.
9. Pull the pump forward.
10. Unclamp the pump outlet hose.
11. Remove pump
12. Unclamp the large bellow on the pumps inlet and inspect for debris.
13. Clean pump and fitler w/o getting water on the pump.
14. Install in reverse order. Remember, it is much easire to put the inlet bellow and outlet hose on the pump before you put into the washer
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
SOURCE: I have an HE2 Elite Kenmore front load washer. I
Sounds like a control board issue. Not much else for you to do but wait
Eric
SOURCE: I have a HE2 kenmore front load washer. On the
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
begin troubleshooting right at the motor. Why start there? Because the motor is one of the prime suspects and it's easy to check. Remove the back panel and unwind the belt from the drum pulley. Now turn the motor pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you have a bad motor.
If the motor pulley turns smoothly and easily by hand, next step is to run the motor with the belt still removed from the motor pulley. If the motor seems to run fine that way, put the belt back on and run it again. If the motor won't run under load (with the belt on), then that's another sign that the motor is bad.
Suppose the motor turns easily and freely by hand but won't run either with or without the belt. This is a more subtle condition because we're probably dealing with a bad MCU or flakey wire harness somewhere between the motor and MCU, or between the MCU and the CCU.
One trick that often works at this point is to remove and reinsert all wire connections at the board and motor. This tends to clean the small amount of corrosion that will build up on the connections. After you do this put the machine into a service cycle (see the instructions in the tech sheet found inside the unit or you can ). Part of the service cycle is running the motor at certain set speeds which checks the tach.
If you've removed/reinserted the wire harnesses and still no joy, then usually the problem is the MCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mine is doing the same thing. I start it & it clicks so I'm thinking it's going to start washing only to come back later with all the lights flashing on it. My husband took it apart & the drum will spin as long as there is no power to it, but once the door locks it will not spin. It's like there is a braking system on it or something. The motor & pump still seem to be working. Also, the mold problem is AWFUL!!!
