Code F-54: I know what the code is and I have found how to troubleshoot on-line, however, I need my manual to refer to some of the solution and I can't find my manual. Does anyone know where I can d
code 54 (DDC#( flashed ) refers to vehicle speed sensor fault
code 55 (DDC# flashed)refers to other ECU fault ( this fault is logged in conjunction with another fault to indicate missing information from another ECU. it also refers to J1939 data link fault
ok code 12 is start code and 55 is end code they will always be there but code 54 refers to cam shaft sensor no continuity check wiring at sensor if looks ok replace sensor does the van run if so how well no power misfire stalling let me know like to make a note of the symptoms for code 54 for my records thank you hope this helps you
code 12 means the battery was disconnected within the last 50 key cycles. ignore this code. code 13 means no change in map reading and the baro reading at start up. check for vacuum line break or loose connection. If vacuum lines are ok, replace the map sensor if the codes still exists after the code 54. Code 54 is no fuel sync to the pcm. Replace the camshaft sensor under the cap, then when the vehicle is running, check and see if code 13 is still there (erase the codes first).
F54 = Motor Control Overcurrent
Does the basket turn freely? If not, determine cause of friction.
There is a detailed repair manual inside the machine. If you open the
top of the machine with a screw driver in the front you will find the
manual on the inside of the front panel.
The model is : Whirlpool Cabrio WTW6600SB2
