I have the blub out . Is there signs that you can see on the blub that shows if its out or not . Could it be the color wheel and how do you replace it . I have replace the TV with a new one but i would like to see if i can repair this one . Thanks
SOURCE: color wheel or fan?
Sounds like the color wheel has shatterd, thats a fairly common problem with that model.
SOURCE: RCA DLP TV needs color wheel replaced
I used the internet and found others who had the same problem. Two individuals had a brief description on how to replace the color wheel in a DLP TV. Three small torque screws and a ribbon connector was all that was need for removal; once the access panel on the back was opened. I would guess that this process is the same for all DLP TV's, with some small variations!
SOURCE: no picture and i replaced the bulb
Joe,
I've never heard of a color wheel costing that much even with labor included - I think I'd try to find another tech for his advice.. If you have trouble locating one try NESDA or let me know what city/state you're in and maybe I can help recommend someone.
That said, if the lamp is good the next logical thing to check is the ballast. If the ballast is not supplying voltage to the lamp then it clearly won't light. A ballast is not that expensive, similar to a ballast in a floresent light - only a bit more complex. In any event I would strongly suggest finding a real professional first we are out there...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
[email protected]
SOURCE: 62" LG Rear Proj DLP TV color wheel replacement
I just had to replace the color wheel chassis which ran $700.
SOURCE: Replaced lamp. TV does not respond
Hi, do you hear clicking or like a start up sound? if you do it could be an issue with the ballast,that's the board that powers the lamp.Here's how to replace it: http://guides.fixyourdlp.com/samsung/bp47-00033a.php Does your TV make a "whining, whirling, clicking, or humming noise?" If the TV have the infamous blinking lights problem and you're replaced your lamp without success, it's most likely a problem with your color wheel. The Samsung BP96-00674A color wheels spin anywhere from 6,000 to 15,000 revolutions per minute (RPM’s)--It is one of the few consumable parts in your Samsung TV. The average life expectancy from our data logging shows the Samsung color wheels are fairly reliable with a MEAN average of 5-8 years. Here's how to replace it:http://guides.fixyourdlp.com/samsung/bp96-01579a.php Also make sure door cover is properly shut and also reset lamp timer by unplugging tv wait 5 min and plug it back again.God bless you!
One more thing . AT first the corners were blue , now it has spread over 3/4 of the screen .
