My canon PIXMA MP450 all-in-on-printer is showing U059 the following ink cartridge cannot be recognized i tryed to put the old ink tank in but it said the same thing I relay on this I need it to print my college work off :(
Basically, there is no solution for your case. This happens especially for Canon product.(called e5 error) Once a cartridge is not recognizable, there is no way, you can use it.
The only way you can do is, replace with brand new one. This is typical Canon problem especially when you refill or re-use your cartridges.
You may see some solution from web such as reset the printer, do somthing to printer software... But non of these methods are working.. Even if there is one, it must be very difficult to do it for individual users.
However, as for a prevention, make sure unplug the power cords before insert or eject the cartridge from printer. In that way, you can at least reuse your cartridges for refill. Hope it helps.
Testimonial: "thanks for the help mate will try it :)"
This error code (U059) indicates that ink cartridge is fault. You should replace the cartridge with new one.
Source: Printer Clinic
