Question about Panasonic Lumix DMC-FZ30 Digital Camera
I have a Lumix DMC-FZ30 which I bought in late 2006. my problem is the LCD screen has gone blank, ( all white). The eye-piece still works, but because of my eyesight it is difficult for me to read the settings etc.The rest of the camera seems to work fine.
    President:
  • 287 Answers
Hello Frank! Welcome to FixYa!
If LCD screen has gone blank but eye piece still works best and as you told that you are unable to read the settings then just follow the given steps to reset the Camera
First of all, Turn on the camera. When the camera is turned ON, Press MENU button, Then Press right Key. Now you are here on Settings, Now move front dial to switch pages of settings to 3/4. Here you have to keep intention that you have to move front dial to three times because you have yo move to setting page of 3/4
Now you are here on settings mode where first option as RESET, Now Press right key and the MENU key, It will rest the camera to default settings.
For more details, i am providing you the manual of Panasonic Lumix DMC-FZ30 Digital Camera,To download manual CLICK HERE
It will help you alot, You need Adobe Reader Software to open this manual, If you don't have download it then you can open this manual. It will provide you in all the operations of Panasonic Lumix DMC-FZ30 Digital Camera.
I hope you have clear picture in your mind. Don't hesitate to let me know if you have some confusion.
Sir, If you find my service helpful for you the your Rating as FIVE STARS and your Words of appreciation will be esteemed.
Thank you for taking my service and for using Fixya
Concerned: Muhammad Uzair
Posted on Dec 13, 2011
  • 1 more comment
  • Frank Allen Dec 19, 2011
    Dear Muhammad,
    I followed the instructions you gave me, but it didn't solve my problem. It seemed to me that your instructions missed a step or two. I downloaded the manual for the camera, but that did not offer any solution to my problem. Can you please try again, befor I request a refund !
    Thank you,
    Frank Allen
    Dear Muhammad,
    I followed the instructions you gave me, but it didn't solve my problem. It seemed to me that your instructions missed a step or two. I downloaded the manual for the camera, but that did not offer any solution to my problem. Can you please try again, befor I request a refund ?
    Thank you,
    Frank Allen
  • Muhammad Uzair
    Muhammad Uzair Dec 21, 2011
    Hello Frank!
    No i didn't miss any step, May be because of your screen blank, You are missing or overlooking the step. Yeah the Manual i provided you didn't trouble shoot this problem but i have given you that if you face any difficulty, You can take help from Manual in using the camera.
    The procedure i told you is the exact description you can follow to Reset your camera, I have also given snapshots of the screens for your ease.
    Well try again, i hope it works.
    Thanks Frank. Wish you good luck
5 Suggested Answers
Jeap
Jose Pais
  • 114 Answers
SOURCE: Can't delete photos from the memory card
just format the card in the computer, find someone with a card reader and format it there, after format on the camera.... and hoppefully the problem will be solved
Posted on Feb 07, 2007
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Need replacement instructions for my DMC-FZ30 digital camera
You can download required user manual from HERE or click Panasonic Support and type model number in box to get manual.
Posted on Jan 13, 2009
Anonymous
  • 83 Answers
SOURCE: lumix DMC- FZ30 - screen is black when camera is turned on
I understand that you've tried all the obvious tricks like resetting to factory settings etc.
Sounds like a CCD/shutter failure I'm afraid. FZ30 are not known for failing CCDs, but I've seen shutters fail on various lumix-es, so in this case I would suggest replacing the shutter. To be precise, replacing the shutter itself is a massive pain in the **** on this camera. It's much easier to replace the whole lens-it contains the shutter. You'll need to get a donor camera (ebay ;) and do the transplant. Swapping the lens is relatively easy if you're ok with midly fiddly things. Oh, and make sure you take notes which screws go where when dismantling the camera - and be careful with ribbon cables for the LCD.
Good luck,
Raf
Posted on Nov 05, 2009
Ty Price
  • 11967 Answers
SOURCE: I would like to restore
Just go into the menu and find "reset".
Posted on Oct 12, 2010
Ty Price
  • 11967 Answers
SOURCE: an you tell me how
You can download a copy from the support section of the Panasonic website.
Posted on Jan 25, 2011
I bought a panasonic dmc-fz30 but it did not have the original cd rom disk. Where can I get a replacement?
usually the manufacturers have the correct disc. they can send you a new copy if you didnt get the correct disc to begin with. or try their tech support web page.
Aug 23, 2011 | Panasonic Lumix DMC-FZ30 Digital Camera
Hi I have my FZ30 for 5 years and as of now the lcd screen when I turn it to sit flat at the back of the camera goes all fuzzy and white, yet in all the other positions it is okay.
I have exactly the same problem with you. I can tell you for sure that the problem will be and to the other positions! Yet I couldn't find the cause of the problem. If you find it share it with us. Thanks
Apr 30, 2010 | Panasonic Lumix DMC-FZ30 Digital Camera
FZ30 with serious colour imbalance
Go into the menu and find "reset"...follow the on-screen instructions. If this doesn't fix the problem, I would return the camera.
Jan 14, 2010 | Panasonic Lumix DMC-FZ20 Digital Camera
Try taking the battery out and trying again.
May 10, 2009 | Panasonic Lumix DMC-FZ30 Digital Camera
Lumix DMC- FZ30 - screen is black when camera is turned on
Check if you have activated the Electronic Viewfinder (EVF). Press the EVF/LCD button to switch to the LCD screen. If this fails to solve the problem, change the mode dial to Auto (the red camera icon) or 'P' and try again. If even this does not work, check with the nearest authorized service center.
Feb 06, 2009 | Panasonic Lumix DMC-FZ10 Digital Camera
Jan 13, 2009 | Panasonic Lumix DMC-FZ30 Digital Camera
Update to 8 gig card
try to use lesser memory cards like 4 GB or 2 GB
Dec 17, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
The camera's LCD screen goes black every so often
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
Aug 31, 2005 | Panasonic Lumix DMC-FZ30 Digital Camera
Panasonic Lumix DMC-FZ30 Digital Camera Logo
85 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
