Started noticing these horizontal lines going across the top and bottom few months ago and since then the number of lines have increased and now it is a rectangular box on the top left and right. I am hoping its just a circuit board that needs to be replaced but not sure how to confirm which one? Any advice?
HI,
Your tv have problem with the T con board. The t con board drives the Pixels in the lcd screen . If there is some problem with the t con board then this can exibits such problem as you mentioned. Normally you can find the t con board in the bottom center of the lcd coverd with a metal cover. Its part number is SONY T-CON: E40951307. If its avilable then try to replace the same which will solve the problem. Its a regular complaint with the Lcd tv's. I have added the picture of tcon board.
Som times if there is any loose conatct in the pannel connection which comes to the t con board then also the same problem can occur. Before going to replace the board do one thing remove all the connections to the t con board and reconnect it. Some times it will solve the problem. If you need any more assistace feel free to conatct me through fixya.
Ajin
Hi prabhjitb,
Check the following link You can find a new t con board for sony KDL 46W4100
http://www.shopjimmy.com/sony-1-857-131-...
Ajin
Visit the site named 'Electro-help' for more
details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to the latest updates. It will make search easy.
There are more than 1350 posts to different brand TVs now. Pull up older posts
there.
Thanks for the help Ajin. I could not find a board on the bottom centre of the TV but did find a board with a metal cover on the top center. Also, I could only find a used TCON board on ebay but do you know of a website where I can buy a new board that I can replace.
[IMGhttp://i41.tinypic.com/316kidj.jpg[/IMG]
Thanks.
Prab
