The error message E6 F2 comes on and then the screen goes completely blank
If you have a Whirlpool oven, the F2 E6 error means that the Cancel key line is open. You will need to replace the keypad or the keypad and controller board (if a single assembly) if the keypad doesn't respond to a press of the Cancel Key.
I hope this helps.
E6 F2 Error Code = Faulty Control Board.
This is the most common board failure symptom and can only be due to the control board. Since the techsheet decodes this to “cancel key line drive open”, many people suspect the keypad is bad. The keypad is not causing an E6/F2. Based on years of experience, E6/F2 is never anything other than the control board….. Send the control board for remanufacture to FixYourBoard.com We offer these from our inventory, and repair them with a two year warranty.
E6 /F2 is always a problem with the control board. Many times it is accompanied by display problems. It can be repaired quickly and reliably www.fixyourboard.com
