Error #6 is the disk can not be read because it is upside down. If you are getting this error and the disk is in fact right side up you have other problems with the unit such as the Read Write Head is dirty or damaged. Possible that something got in there inserting and removing a disk. You have to remember the small size of the working components here does not require much to muck up the whole system. If this happens with all the disks you try make sure they are clean and devoid of surface damage as scratches will make it impossible to read. Remember this is an optical drive so Fingerprints and Scratches are not part of the language these things read. If it is just the same disk, get a different one. As I've had happen to me that code ended up being a trip to buy a new unit on sale with free installation as it died. But that is what the code means.
>> The Device has a bad block of memory, which Windows attempted to read.
Which CD/DVD disk are you trying to _read_ ?
Can you read this disk in a different computer ?
If not, then the disk is scratched or greasy or otherwise damaged.
Does the error occur when you try to start to _write_ ?
If so, the "blank" CD/DVD media may not be compatible with your hardware.
Find a "writable" disk from a different manufacturer, and try to write to it.
If that works, then you may need to do a "firmware-upgrade" on your CD/DVD-writer, to make it compatible with newer "blank" media disks.
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
HI,
Try a laser cleaning disk, you may have debris on the laser head itself.
Also try different disk formats, such as Games-Music-DVD And bluray.
Find out if it,s reading anything At All.
Mike @ Compurepair.
