Question about Denon Audio Players & Recorders
Fiber optic wire hooked to Denon AVR 1706
Fiber optic is hooked up from new Panasonic TC-P50S30 to Denon AVR-1706 . HDMI Cable is hooked up from Panny to Sony DVD recorder. Satellite is ran through the DVD. We have no problem with getting sound for everything else but cannot get Denon to give us Surround sound when we watch antenna TV. We have tried two different times to hook up with what we thought were solutions but have had no success. I believe many people will say that Denon is not the easiest manual to read. Thanks for your help. Diagrams would help greatly.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
Go to page 19 in this manual - it should get you to where you want it to be.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/033/033AV1706B.PDF
Posted on Oct 11, 2014
6ya staff
SOURCE:
Anonymous
SOURCE: Sony surround sound hookup
Did you get a reply? I need the same answer
Posted on Jan 08, 2008
Anonymous
  • 151 Answers
SOURCE: no surround sound on ps3
Set the sound out put on ps3 to the optical out put then set sound on ps3 to give you dolby digital,dts,aac etc.
PS, do not set the hrtz range above 100 as this can damage your speakers.
hope this helps.
CABLE GUY.
Posted on Jan 06, 2009
Anonymous
  • 51 Answers
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Posted on Jan 08, 2009
Anonymous
SOURCE: bose 321 have dvd picture but no sound HDMI
check the power suply behind the acoustimass set to 115v, not to 230, that will solve you problem
Posted on Oct 12, 2009
Anonymous
SOURCE: I have an LG all in one home theatre system, LCD
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Posted on Feb 08, 2010
How to hook up a denon avr -1706 receiver to a lg smart tv
When connecting your AVR-1706 to your LG TV, you will most likely be limited by the connections on your AVR-1706 as it does not have any HDMI capability.
In this case, depending on your LG TV, you would get the best video performance by using the component video connections from your TV to the Receiver. These are the one labeled Y, Pb, and Pr. These are special cables and you will need 2 sets if you want to run video out of your TV (perhaps you are using the internal tuner). Refer to page 6 of your AVR manual for the TV video inputs. Please note you will only use one type of input such as Component, S Video or Composite (descending order of performance). You must connect the Video Out from your AVR to the back of the TV's Video In as shown on page 6 as a minimum to get signals from devices other than the TV.
On page 12 of your AVR manual you can see the connections for TV outputs including the audio connections to the AVR. In the case of audio, you can either use Optical Digital (Toslink) out from the TV or coaxial (RCA) cables: Again in descending order of performance.
If you don't have the AVR-1706 manual handy, you can see it at the following link: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/033/033AV1706B.PDF
Mar 02, 2015 | Denon Audio Players & Recorders
How do I set my receiver to read TV/CBL Dolby Digital. It is a AVR 789
The Dolby digital signal is outputted only through the Optical or Coaxial socket of the CBL box. you will have to get an optic fiber or coaxial cable depending which cable box you have and connect it to the digital input of the Denon receiver. The Denon's digital input are already assigned at the back. Eg: Optic input might be labeled CD so if you are connecting the CBL box to the optic input remember to select CD on the Denon to hear the cable sound, same goes with the coaxial input.
Aug 27, 2011 | Denon AVR-788
I just wanted to know how to hook up my lg 3d blue ray player. i'm not home so i can look at anything. I need to know how many HDMI cords I may need to plug in my tv, digital cable box, the a/v...
You can do this two ways.
Way #1 connect your cable box to your a/v receiver with one hdmi cable. Connect your blu ray player to your a/v receiver with a second hdmi cable. Lastly, connect a third hdmi cable from the a/v receiver to the television. (3 hdmi cables needed this way)
Way #2 connect your cable box to your television with one hdmi cable. Connect your blu ray player to your television with a second hdmi cable. Connect your a/v receiver to your television with a RCA/composite a/v cable or with a fiber optic cable. Connect your cable box to your a/v receiver with a fiber optic cable or RCA/composite a/v cable. Lastly connect your blu ray player to your a/v receiver with a fiber optic or RCA/composite a/v cable. This method takes 2 hdmi cables and three sets of fiber optic and or RCA/composite a/v cables.
Can't get more specific than that without having the a/v receiver's model number, type of cable box, and television model number. Hope this helps.
Jul 22, 2011 | Audio Players & Recorders
I have connected to my 2311: HDMI 1: Oppo BDP 83 HDMI 2: Denon DVD 1740 HDMI 3: Apple Mac Mini Issue: The Mac Mini works fine and I have audio and video through the receiver, but for the BD and DVD only...
hi,
You have to check the digital audio assignment of you AVR for HDMI 1 and HDMI 2. There is three options for the digital audio for HDMI 1 and HDMI 2. You can set it as optical ,coaxil, or the HDMI itself. In you receiver the assignment may be in optical input or in coaxial input for the two HDMI inputs.
1. Go to the system setup
2. Select input setup
3.Select input assignment.
4. Select all the three input ,you are using as HDMI
ok
Apr 11, 2011 | Denon AVR-2311 Receiver
I just purchased a . Samsung 50
No, you would be better off sending the video signal from your sources(satellite,digital cable,DVD,BluRay player,any digital HD source,etc.)directly to your Samsung TV, and then use the fiber optic output from the TV to transfer the audio signal to your Denon receiver, or another way is to send all video signal to your TV and send all audio signal to your Denon receiver seperately, keep in mind that there really isn't a good reason to send video into a Denon receiver, that processes sound not picture! Good Luck !
Jan 05, 2010 | Denon AVR-3805 Receiver
No sound when ps3 is hooked up to a denon avr 1609
The 1609 only has video on the HDMI. No audio comes through the HDMI cables. Hook up an optical cable between your ps3 and the receiver and you should be good to go.
Dec 29, 2008 | Denon AVR588 Receiver
Playstation 3 hook up problem
I ended up using the component in cable hookup and fiber optic digital audio instead of HDMI - works fine.
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
No audio from PS3.
works great, plenty of plug-ins, easy set up, but you get 2 hdmi ins 1 out. hdmis' work great one cable for sound and video but the denon avr588 doesn't accept sound through the hdmi cable.(it's noted in the manual) why not? i don't understand. so you go with optical or coaxial for audio. it works but extra cables.
Dec 28, 2008 | Denon AVR588 Receiver
HK AVR 645 7.1-Receiver Turns off when sound starts to come through
did you figure it out? I bet your problem is the same as mine NOT HDCP complitant.... its gettting a signal from the bluray that can not be accepted... research HDCP compliant... my ONKYO does the same thing...
Jul 10, 2008 | Harman Kardon AVR 630 Receiver
155 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
