Question about American Range AF45LP Deep Fryer
How much oil should i use - American Range AF45LP Deep Fryer
Posted by JOE LACOPPOLA on
Susan Bennett
    Scholar:
    New Friend:
  • 99 Answers
Your fryer should have a fill line in the pot that you would use as a guide and not fill beyond that line....It should be at the back wall of the inside pot of the fryer....It's going to be alot lower than you would think, as the oil will bubble up and rise when you drop a basket of frozen product in the hot oil, but you don't want it to come over the top, so use the line inside the pot as your guideline. Also, you can look at the container your oil comes in too. When American Range says a 45 lb fryer, what they mean is it will cook approx 45 lbs of product, that's not 45 lbs of oil.... but it does end up being close anyway. I'd buy 2-3 of the commercial containers of oil, like 20# or so, and use what you need, save the rest.... Susan REO
Posted on Dec 26, 2011
Oil pan leak
For oil pump,oil pump pressure,oil warning light,oil low,oil ewplacing and other car engine oil problems,the help links are provided below.Click the link to go through the procedure :-----Oil light came on and the car died?http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html--------How to replace Oil filler cap or breather cap?http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html---------Oil pouring out from left front of engine?http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html------Common Causes of Car Oil Leaks?http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html--------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html--------Oil change details?http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html---------Low oil pressure light?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html ----------
Car Turns OFF due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html----------Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
Feb 28, 2012 | 2001 Kia Sephia
Where is oil pressure switch on 1995 oil pressure switch
Car oil leak?
This will help.
Thanks.
Feb 26, 2012 | 1995 Isuzu Rodeo
Oil filler cap left off after oil change, 2010 Subaru Outback. Oil level is fine. Could this have caused any engine problems?
Car oil leak?
This will help.
Thanks.
Feb 14, 2012 | 2010 Subaru Outback 2.5i
How to replace the oil pump
Car oil leak?
This will help.
Thanks.
Feb 12, 2012 | 2000 Oldsmobile Alero
Oil pump
Car oil leak?
This will help.
Thanks.
Feb 09, 2012 | 2003 Kia Spectra
2002 Lincoln LS V6 oil leak
Car oil leak?
This will help.
Thanks.
Feb 07, 2012 | 2002 Lincoln LS
1998 pontiac firebird V6 3800...NO oil pressure and noisey valves. Have replaced oil pump and oil sending unit,claned oil pan,pick up tube and all parts....I dont know what else to do. Could someone please...
Car oil leak?
This will help.
Thanks.
Feb 05, 2012 | 1998 Pontiac Firebird
Oil pressure light comes on at idle
Car oil leak?
This will help.
Thanks.
Feb 05, 2012 | 1997 Porsche Boxster
1995 dodge dakota truck has no oil pressure
Car oil leak?
This will help.
Thanks.
Feb 04, 2012 | 1995 Dodge Dakota
How to replace a oil pump
Car oil leak?
This will help.
Thanks.
Feb 03, 2012 | 1999 Oldsmobile Aurora
American Range AF45LP Deep Fryer Logo
105 people viewed this question
Top American Range Kitchen Appliances - Others Experts
Mike
Paul Carew
Are you an American Range Kitchen Appliances - Other Expert? Answer questions, earn points and help others
