Google Chrome Logo
Anonymous Posted on Dec 12, 2011
When I click on a link it takes me to my home page instead of the link address.
  • Duane Wong
    Duane Wong Dec 12, 2011
    Do you mean that when you click on a blue lettered link that it goes to the wrong html?
  • Anonymous Dec 12, 2011
    Yes
Duane Wong
Level 3:
  • Master 6,826 Answers
  • Posted on Dec 12, 2011
Duane Wong
Master
Level 3:
Answers
6826
Questions
6
Helped
2860355
Points
20233
The only thing I know that you can do to Chrome, which is a small but efficient web browsing program, is to uninstall it and reinstall the latest version. If it still does this, maybe test another browser like ie9 or Apple's Safari to see if the problem can be duplicated there.
1helpful
Make Google news my home page
Hi
Load Google Chrome. On the right side of the address bar is an icon consisting of 3 horiz bars. Click on this and then click on settings. A webpage will open. Under the On Start-up heading, click a dot into "open a specific page" and click on "set page". In the box which comes up type the address of the page you want. In your case I think it is
https://news.google.co.uk/nwshp?hl=en&ei=0iI8VIyzAcnnaLLggkA&ved=0CAoQqS4oCA
Having done that delete any other address that may be shown and close the settings page. Restart Chrome and it should open to Goggle News. Other browsers will have different ways to set the Home Page, but the above link will take you to Google News no matter which browser you use
Cheers
I want to make google my home page
It depends on what browser you are using, but it is pretty much the same process for all browsers for setting your home page.
I will give example using the Firefox browser.
1. Go to the Google page by typing www.google.com in the address window then press enter. - You should see the google website page displayed.
2. Double click on the address window to highlight the address then right-click with the cursor still on the highlighted address and select "copy" from the dropdown menu.
3. From you web browser's menu select "Preferences" - in Firefox click on "Edit" then "Preferences" in the drop-down menu.
4. The preferences window should appear opened to the "General" tab. If another tab is opened then click on the "General" tab.
5. You will see "When Firefox starts: Show my homepage" - If "Show my homepage" is not showing then you can select it by clicking on whatever is in the window currently and choose it from the dropdown menu.
5. Next - put the mouse cursor in the "Home Page:" window - then right-click and select "Paste" to past in the "Google" site address that you copied from the address window in step 2. above. Alternately, instead of copying the Google website address into this window you could simply type in "www.google.com" and it should work.
6. Final step in setting your preferences - below the window that you just filled in step 5. is a button/sign that says "Use Current Pages". Right-click on this button/sign.
7. Close the preferences window. Next time you startup your browser the google website should appear as your home page.
Good Luck,
walt
Nov 17, 2013 • google.com
Make Google my homepage
Chrome:
  1. Click the Chrome menu snp_2696434_en_v1 on the browser toolbar.
  2. Select Settings.
    • Add the home button to the browser toolbar
      Homepage button is off by default. Select the "Show Home button" checkbox in the "Appearance" section to show it on the browser toolbar.
    • Set your homepage
      When the "Show Home button" checkbox is selected, a web address appears below it. If you want the Homepage button to open up a different webpage, clickChange to enter a link. You can also choose the New Tab page as your homepage.
IE:
  1. Make sure you've closed all open tabs, then open Internet Explorer for the desktop.
  2. Tap or click Tools, and then tap or click Internet options.
  3. Under the General tab, enter the web address of your new home page, and then tap or click Apply.
FireFox:
  1. Open the website you want to set as your home page. If you want a blank home page, open a new tab.
  2. Click the icon to the left of the web address, drag it to the Home button, and release.
  3. Click Yes to set this as your home page.
Safari:
1. Click on Safari in your Safari menu, located at the top of your screen. When the drop-down menu appears, choose Preferences.
2. Select General from the Preferences menu, which is now overlaying your browser window. Once General is selected, you will notice a section labeled Home Page in the main window of the Preferences dialog.3. Directly to the right of the "Home Page" label is an edit field containing your current home page URL. In the example below, Safari's current home page is http://www.apple.com. To modify this address, simply erase the contents of the edit field and replace it with the desired web address.
4. Directly below this edit field you will see a button labeled Set to Current Page. Clicking this button will change your home page setting to whatever page you are currently viewing within the Safari browser.
5. Once you have completed your changes, close the Safari Preferences dialog by clicking the red circle/x located in the top left hand corner of the box.
I Want BING HAS MY HOME PAGE
The is done differently in different browsers. The three most common are Internet Explorer, Firefox, and Chrome. I'll list the steps for each.
Internet Explorer:
  2. Click Tools, and or click Internet options.
Under the General tab, enter the web address of your new home page, and then click Apply.
Firefox:
  1. Open the web site you want to set as your home page. If you want a blank home page, open a new tab.
Chrome:
  2. Select Settings.
    • Set your homepage
      When the "Show Home button" checkbox is selected, a web address appears below it. If you want the Homepage button to open up a different webpage, click Change to enter a link.
Can u get my home page bk on to i explorer please
Open Internet Explorer and click view followed by internet options. The home page address should be displayed in the box.
You may enter in any address to be your home page. Enter it as a web page address. Example: http://www.google.com
Take care!
damnor01
I installed babylon windows internet explorer and it substitute google windows internet explorer and I want to get it back as homepage please tell me how
Hi. This is fairly simple to fix.
First open firefox, from the way you describe it , then it opens to google.
thats ok.
Now go to the babylon website.
Next, click you tools tab, and then select options.
On the tab that says general is the place to make changes to your home page.
Right click on your address bar where you have babylon web address, and click copy, or copy link location, whichever it offers
Next delete the google address in the home page block, and paste the babylon one into it.
Then click ok.
Close your browser, wait about 15 seconds, this allows the system to recognize the changes, and then open firefox again.
Now you should have babylon as your home page instead of google.
Came home from vacation went toconnect to router
Is there any computer connected to the router ?
If not then you will need to connect the computer
to the router.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the
router.
Click Here for step by step instructions
15helpful
4answers
The page you requested was not found in farmville
try this get in to your account privacy settings, choose applications and websites, edit blocked applications.
if you found farmville then click the "remove"
you should be able to see farmville on facebook again
it works for me
1helpful
Dell v14 msn homepage stopped working and not sure why msn link broken
I guess you lost your Home Page link to MSN, right? If so, use your browser--probably MS Internet Explorer--to go to www.my.msn.com and sign in.
From the MS IE top menu bar, select Tools, then Internet Options. In the General tab you will see Home Page on top and your home page address should be in the Address line. Click Use Current.
Your home page should be restored.
38helpful
5answers
I can't get to http://192.168.0.30/
Every time I try to begin the configuration for my DWL-G730AP router, when I type the http://192.168.0.30/ in the URL, Gateway and Google tell me they can't find this address and instead give me a list of suggested web pages. My D-Link router instructions say to type the above in...
Top Google Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
