Normally come with a base stand, Amazon do several different wall mounted brackets, depends on size of TV and if you want a swiveling mount or not. Hope this helps
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
hi there, swivel stand of the TV is all detachable by screws. try to locate them underneath or sometimes it is cover with rubber caps so it is not easily noticeable. if you remove the stand then you need to purchase a lcd wall mounted frame, I suggest the universal one for this is adjustable up to 42 inch LCD monitor. hope this helps please rate and vote.
1. Unplug all of the cables and cords from your GV42L
FHDTV10A.
2. Place the GV42L FHDTV10A face down on a soft and
flat surface (blanket, foam, cloth, etc) to prevent any
damage to the TV.
3. Pull the stand cover off by squeezing the sides to
release the retaining plastic tabs.
(This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
4. Remove the four (4) screws
(screw's specs: M4, 0.7 Pitch,
15mm long) so that the stand
base can be removed.
5. Gently remove the stand
base
6. Now, the GV42L FHDTV10A can fit securely to a
mount (sold separately) by utilizing the mounting
holes in the center of the back panel of the TV.
Please make sure to read the instructions of your
specific mount to properly hang the GV42L
FHDTV10A
That seems to be a good question. Page 12 of the manual refers to the mounting instructions for alternative mounts for specific details. I'm guessing that Hitachi has alternative mounts for specific models, and the swivel removal instructions would be found there.
I'll keep looking. Please post if you find the instructions.
I picked up a wonderful three tier glass table stand for this exact T.V. at Wal-mart for $189.99, This is fairly inexpensive compared to some of the options out there, but its well worth the money. The thing that is great about this is that there is no holes to drill, no making sure its level. You just put the setup together yourself, attach the bracket to the back of your t.v. then hang it up on the stand and your good to got. It's very durable and you can swivel left to right. If your looking to spend less, there are a million different places on the web offering wall mounts for $29.99 on up.
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
