Question about Pioneer DEH-1300 CD Player
Power but no sound
Cant get sound at all , this is a new install.
Posted by ted g. on
Ron Rossman
    New Friend:
  • 52 Answers
If your car has an OEM amplified system, make sure the blue (or blue/white if your radio has both) is connected to the blue or blue/white in the after market harness adapter.
Also make sure none of the speaker lines are touching metal (grounding out) or touching each other
Posted on Dec 13, 2011
I Hooked up my new stereo and cant get any sound. I put the factory Bose back in and the sound works. Hooked up my new stereo to another car and it has sound. Can anyone tell me Why im not getting sound...
If you had a "Bose" sound system - Factory installed - it should have and Amplified System - which means the original stereo will supply power to the Speaker Amps - that is the circuit that didn't get connected and why there is no sound.
I hope that resolves your issue
Thanks
Feb 22, 2015 | 2002 Nissan Pathfinder
My Iva-Nav-1 cant hear no music turns on but no sound?
You do not mention the year, make and model of the vehicle. Nor do you mention if this is a new installation but, if this situation occured after being installed and the it has never had sound, your vehicle may a factory amp that needs to be powered up.
Aug 28, 2012 | Alpine Iva-nav-1 Car Video Player
Im installing a new stereo for my 1995 chrysler lhs. the stereo works, but why cant i get any sound?
It sounds like you have the "Infinity System". The accessory/antenna wire has to be hooked up to the power wire for the factory installed amplifier (should be located under the passenger's seat). Locate the wire from the original harness and hook it to the amp wire. I hope that helps. Please rate my assistance and leave a testimonial.
Dec 31, 2010 | 1995 Chrysler LHS
I HAD TO PUT A NEW ETERNET CARD IN MY PC AND NOW I CANT SEEM TO GET THE VOLUME TO TURN UP ON MY SPEAKERS. THE VOLUME IS VERY LOW. IS THERE A DRIVER OR SOMETHING THAT NEEDS TO BE INSTALLED
Go into control Panel system and remove your sound card. completely, Power down your computer fully then power back up. It should find your sound card and load drivers for it and get rid of the IRQ problem. It should sound ok now.
Aug 16, 2010 | Computers & Internet
I cant install sound driver at my HCL ES2 desktop?it has been installed but when it displays fownd new hardware it cant search for driver
First remove the driver if installed.Then re install the sound driver and when you connect the found new hardware then dont let your computer find the driver you give the path where you have that diver and then install it.Your problem will be solved if not then look for the latest driver of sound.
Please rate me if this solution works for you
Thanks......Have a great time
Jun 30, 2010 | Computers & Internet
Static from desktop speakers
Sound card may be bad. Uninstall all software and drivers for the sound card. Remove the sound card and clean the gold contacts gently with a pink pencil eraser to remove oxidation and make them shiny. install sound card in a different slot if available. Install driver and try again. test with headphones too. If still just static, try newer sound card driver. If still no good get a new sound card.
Aug 08, 2009 | MSI RC410M-L Motherboard
No sound with new computer
chk the multimedia drivers may be the drivers may not be installed. run motherboard CD and instal sound drivers
May 24, 2008 | Microsoft Windows Vista Ultimate Edition
Pioneer DEH-1300 CD Player Logo
115 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
