Question about Palm Computers & Internet
Expreprt.exe module not found
Error: expreprt.exe module not found Resolved today with a very simple registry hack. (It took 5-15 minutes)
3 Related Answers
laurelton
  • 49 Answers
SOURCE: error message
Don't dare and **** with the registry unless you k**w what you're doing. And - ** offense - if youasking that question on this site - you don't.
If you mess up the registry, you're computer will stop working. I've done it. I k**w!
Posted on Mar 09, 2008
Vaun kashyap
  • 45 Answers
SOURCE: problem message at startup. Exception Eole sys
it can be enabled or disabled by the option in the system properties and under the advanced tab and option named as error repoting
Posted on Feb 13, 2010
Raj Patel
  • 1042 Answers
SOURCE: after installation of a network
Your best bet is to try a system restore to a point before you installed the bad driver.
Click on START, PROGRAMS, ACCESSORES, SYSTEM TOOLS, System Restore. Then select Restore My Computer to an earlier time. Hopefully you will have a restore point dated just before you installed the driver. Restore to that point and see if it fixes the problem.
Posted on May 19, 2011
I'm trying to install microsoft picture it on my pc (windows7) but a missing pi.exe keeps on apearing,how can I fix this
Free Guides to Fix PC Errors By PcTweaker Skip to content Leave a replypi.exe is part of Microsoft Picture It! 9 and developed by Microsoft Corporation according to the pi.exe
pi.exe Vendor and Version Informaiton : Product name : Microsoft Picture It! 9 Company : Microsoft Corporation Version : Md5 : 33be8a09351e58d22e5a3f35cff5ffa6 Why does my computer have the pi.exe wrong information cue? pi.exe is a file name that often appears in some error messages on the computer, if you frequently receive the error notifications which state that the specific program cannot be processed for the pi.exe file being corrupted or missing, you should consider to fix pi.exe error well for avoiding the related operation problems on your computer.When this file gets corrupted, missing or suddenly become invalid in the Windows system, you will immediately receive the pi.exe error message and you will need repair it as soon as possbile !
If you do not fix nengine.dll missing as soon as possible, you may face the problems below:
"System boot-up failure" "System file corrupt" "Slow system performance" "Blue Screen of Death errors" "White Screen of Death errors" Why need to Fix pi.exe Errors ? When the system has the pi.exe wrong information, it shows that the error has been affecting the Windows system's running stability. If this time not clearing up the pi.exe error quickly, the Windows registry can be easily damaged, and then the unsteady Windows registry will affect the normal use of other softwares or directly make them not work,and the whole Windows system can not be used normally.So, when the Windows system has the error message, we should hurry up to repair it well.How to fix the pi.exe error ? To fix pi.exe error is not that easy before,but now it is so easy ! Please download the Pctweaker software recommended by us, according to the following procedures. You can soon clear up the pi.exe error through a few simple procedures, and in the course the software will automatically repair your computer's Windows registry damage caused in normal operation.
2answers
Rand mcnally 710 navi.exe has encountered error
go on lione and do the back up anbd reset to factgory setting it should be ok
How to fix file \i386\ntkrnlmp.exe error 7
Depending on the cause of error, you need to either change your BIOS settings to default or replace the faulty RAM to resolve it.
Change BIOS settings to default
To apply default BIOS settings, enter your BIOS setup, select and save the default BIOS settings.
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimised defaults press escape then press f10 to save to cmos to restart
Note: When your system loads, the text in the bottom part of the screen contains information on which key you need to press to enter the BIOS setup.
Also, before changing your BIOS settings, note the current settings.
This information will come in handy if you need to revert to your old settings later.
Replace the faulty RAM
If you find your BIOS settings were already set to default, the cause of the above errors could be faulty RAM.
If you have only one RAM installed, then replace it with new RAM to fix the error. In case you have multiple RAM chips, then to identify the faulty RAM chip, take out all the RAM chips, insert them one by one and restart your computer each time.
Discard or replace the RAM chip that generates the error after installing.
Note: You can also use the help of a reliable memory diagnostic tool to identify the corrupt memory module.
Besides incorrect BIOS settings or faulty hardware, another major cause of recurring exe errors is malware infection.
Malware, such as worms and viruses deliberately change the reference points of exe files in the registry.
As a result, exe errors, such as ntkrnlmp.exe errors occur every time an application tries to execute the infected file.
To prevent malware from causing exe errors on your computer, we recommend you secure your PC by installing robust antimalware software, such as Antivirus Plus and StopZilla.
Also, schedule regular malware scans of your entire PC and keep your antimalware software updated with the latest virus definitions and security updates.
I prefer to try the free ones before committing to a puchase
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
Furthermore, ensure that your registry is clean and devoid of unwanted information.
Oftentimes, registry issues are found to be the root cause of many system errors, including exe errors.
Perform regular registry scans using efficient registry cleaning software,
such as RegGenie,or http://download.cnet.com/ccleaner/
registry cleaner its also free
to eliminate any incorrect and corrupt entries from your registry.
hope this helps
2helpful
Problem signature: Problem Event Name: APPCRASH Application Name: msnmsgr.exe Application Version: 14.0.8117.416 Application Timestamp: 4bc935af Fault Module Name: UXCore.dll Fault Module...
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reg in out registry cleaner it will solve ur problem
1helpful
3answers
Stsystra.exe - entry Point Not found What do I do?
It is unavoidable that runtime errors, .exe errors, dll errors, missing dll files, Internet errors, blue screen of death would annoy you after you used your computer for a few of years. Additionally, you probably will find you get a slow computer and have to reinstall your operating system.
It is highly recommended you download the best PC optimization tool. Just follow these 4 easy steps here; you can easily fix any PC errors and speed up your computer in just minutes:
  • 1. Free Download the PC Tune-Up Tool ..
  • 2. Launch it after finishing the installation.
  • 3. Click “Scan Now” button.
  • 4. Click “Repair Problems” button to optimize your computer perfectly.
Fix windows error
Cant use picture motion browser.. where i download pic from camer
it should be on system failure but the rest are not functioning, reupdate your windows system with all any add-ins program to be installed. Errors find in the registry also, need to have Registry Repair Programs to fix that link execute command. Good luck!
1helpful
2answers
Regsvr.exe not found please help me
This is your problem i think: Windows cannot find 'regsvr.exe'.Make sure you typed the name correctly,and then try again.To search for file,click the start button,and then click search.
Most likely you had a virus that installed a Regsvr.exe reference into your Windows registry. If it shows as "missing" at start-up it's because your anti-virus software removed the program but not the reference. You need a registry cleaner tool like CCleaner. It's a free tool that can be used to clean both your registry and delete junk files from your hard drive.
I found a few things you can do: 1. http://tandt-u.blogspot.com/2008/11/remove-regsvrexe-virus.html
2. Just Google CCleaner - download and run it.
3. I found a site. just follow thes steps: http://amiworks.co.in/talk/how-to-remove-new-folderexe-or-regsvrexr-or-autoruninf-virus/
4. I found (maybe) the soultion.you got the error at startup say that regsvr.exe not found.
Plz find the process how to remove this error
Goto-> RUN-> Regedit->HKEY_LOCAL_MEACHINE->SOFTWARE->MICROSOFT->WINDOWS NT->CURRENT VERSION->WINLOGON->in the reght side panel u can see the key SHELL -> in that key u if u see the two names (Explorer.EXE Regsver.exe) plz delete only the regsver.exe(plz do not remove the explorer.exe) Just Press OK
PLZ BE CARE FUL WHEN UR DOING THIS UR PLAYING WITH SYSTEM FILES PLZ DO NOT REMOVE ANY OTHER KEYS
IF ANY SYSTEM CRASHES I AM NOT RESPOSIBLE
PLZ CREATE A SYSTEM RESTORE POINT BEFORE DOING THIS
if you find it difficult, i found a site with the same steps but with screenshots: I found the soultion for the same. http://techrena.blogspot.com/2009/03/remove-windows-cannot-find-regsvrexe.html
I hope it works for you. And please rate
1helpful
2answers
M3plugin.dll
please tell us how to resore requird dll for error
C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.
63helpful
26answers
M3plugin.dll
progra-1maywebs/bar/8.bin/mwbar and 8.bin/m3plugin.dll .may problem with computer
Computers & Internet Logo
Top Palm Computers & Internet Experts
Ekse
Muzahura Frank
Mandeep  Singh
Mandeep Singh
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
