I assume the doors can be manually locked. The problem is in the electrical circuit. That means anything from a faulty switch (the lock / Unlock button) to a loose connection. If both switches don't work then look for a blown fuse. If one switch works and the other doesn't than remove the switch and inspect its connection. If it's ok then check the switch. If both switch and connections are OK then you'll have to remove the door panel and access the lock mechanism.
