Question about Broderbund PrintMaster Platinum 16
How can I run PrintMaster 16 Platnum in Windows 7
I can't install Printmaster 16 Platnum on my Windows 7 computer
Posted by Chhris Yarbrough on
  • Broderbund Master
  • 6,182 Answers
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Posted on Dec 11, 2011
Our business has been using Printmaster 15 for a few years now. We recently bought a new computer with windows 7. Printmaster 15 is obviously not compatible with Windows 7. I bought printmaster 2011...
You can try version 15 in compatibility mode:
Troubleshoot Compatibility
This can help with some (but not all) programs/drivers:
1) Uninstall the program if it's already installed. Then when you install/reinstall it instead of double clicking on the install file right click it and select "Troubleshoot Compatibility"
2) Then click "Try Recommended Settings" and in the next window click "Start the Program" to install it.
3) After it installs see if it works correctly. Please note - some programs may not be able to run in Windows 7.
More details about how to make older programs run in this version of Windows:
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Jul 19, 2017 | Broderbund PrintMaster Platinum 16
How do you make Printmaster Platinum 16 work with windows vista
Printmaster Platinum 16 is not compatible with Vista or windows 7. You can try to use Vista compatibility mode to run older programs in Vista. There is not guarantee that it will work!!! Please take note:- **The installation of an older program to run in a newer OS may also crash your PC too.
Link to How to "Use windows vista compatibility mode" - Use at your own risk!
Good luck
Dec 20, 2010 | Broderbund PrintMaster Platinum 16
I cant get printmaster gold to work on my computer. i have windows vista
Broderbund PrintMaster Gold 16.0 is not compatible with Vista.
Platform: Windows 98 / 2000 / Me / XP
Good luck.
Dec 07, 2010 | Broderbund PrintMaster Platinum 16
Will Printmaster Platinum 16 run on windows 7 I
Oct 24, 2010 | Broderbund PrintMaster Platinum 16
Need a patch for printmaster platinum 10 for windows 7
my wife has a dell computer with window 7 professional operation sistom and i have printmaster platinum 10 only for Windows 95/98/200 NT 4 how i cann install this program in the new computer?
May 31, 2010 | Broderbund PrintMaster Platinum 16
Can i install the print master platinum 16 on my new computer with windows 7
ypu cannot use print master platinum 16 with windows 7 or for that matter vista
Mar 05, 2010 | Broderbund PrintMaster Platinum 16
Can I load Printmaster 16 on Windows 7?
Printmaster 16 will work with Vista and Windows 7, you need to run setup.exe as administrator.
Jan 10, 2010 | Broderbund PrintMaster Platinum 16
Computer store when repairing my computer uninstalled my Printmaster 16. I can only find my Printmaster 16 Program CD. Can I download the Install CD? or how can I find the Install on my computer?
Are you sure it's uninstalled and just not unlisted in "All Programs"?
Go to Computer > C: drive > Program Files >...look for Broderbund or PrintMaster in the list of folders. If you see one, open the folder and look for Printmaster.exe. That will be the program. Right-click on the file, choose Send To and choose Desktop. That will create a shortcut for you.
Nov 12, 2009 | Broderbund PrintMaster Platinum 16
Printmaster and Windows Vista
been running printmaster platinum 8.0 for many years on several different computers . have had it installed and running on my HPPavilion slimline for two years now . problem is that i cant get it too print anything new that i create it will print out older stuff that i have created but nothing new . have checked drivers on print they are all up to snuff , and have uninstalled and reinstalled both the printer and the printmaster program but still cant get it too print anything new that i create . it does print everything else in the PM program. and otherwheres on my computer
Feb 09, 2008 | Broderbund PrintMaster Platinum 16
Computers & Internet Logo
382 people viewed this question
Top Broderbund Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
