Had to upgrade mobo to use new cpu and on/off wires don't fit on new mobo. Where can I get a replacement wire set for the power button so that it will work on a new mobo? Old mobo has 14 pin where on/off power wires plugs into, 3 pairs of wires for 3 different LEDs and 1 pair of wires for the on/off power button. The new mobo I got I was assured would work, and of course it doesn't; it has a 9pin on the mobo for the on/off power cable plugin. Is there an adapter that would work or am I out all I paid for new mobo and cpu?
SOURCE: Motherboard settings
axesus here is a picture of general mo ther board. Just try to study and find the port matching in this figure.
I think it will help you to fix your problem.
Thanks
Iqbal
SOURCE: Can not upgade memory from 2G to 4G
use 2GB DDR2 PC2-6400 800MHz CL 4-4-4-15 / Platinum / Revision 2 / Mirrored XTC Heatspreader Dual Channel Kit OCZ2P800.R22GK from Frys their stk # 5008315 or similar. works great on mine
SOURCE: mismatch connection,plug vs pin after swithing motherboard
Hi there.
On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW.
Have a look at these pictures for an idea >>>>>>
Good luck and thanks for using FixYa!!
SOURCE: Acer Veriton M464 E4700 2.6Mhz cpu upgrade on MCP730 Mobo
Go to www.newegg.com and whatever you want to upgrade click on that item and match it up with your current board (by looking at the specifications and matching them). I suggest to buy a new mobo and all new processors and ram. You can use your old case, hard drive and all that good stuff that is removable.
