Question about Jabra Radio Communications
Jabra sport will not charge
New Jabra Sport charged correctly the first time. Used it for three hours and plugged it in to charge again. Red light blinds like it is charging but it never goes to green or charges.Tried to reset as per the manual but because there seems to be no charge it will not work. Sent email to Jabra support but after 3 days still no reply.
Posted by jack861 on
  • siroteo Jul 23, 2012
    I have the same problem. I plug and unplug for several times, so it works again.
Joerock1981
    New Friend:
Same problem did you call the 800 number?
Posted on Jan 11, 2012
Testimonial: "I did call and they sent me a new headset. I have not had a problem with the new one. "
Why can't I turn on my Jabra sport after charging?
Could be. No battery has a lifetime forever. But perhaps you did not unplug it correct?
Try plugging it in and look if any light goes on when plugged in on the charger. You don't need it on the charger for a long time. Then unplug it an try to start it again. also check if all contacts on the Jabra and on the charge cable are clean and nothing can block the current.
May 23, 2014 | Jabra SPORT Earset
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Dec 30, 2010 | Jabra BT150 Wireless Headset
Jabra BT2050 blinks three times; doesnot pair up
Hold round center button for 10 seconds, light will stay on and be in pairing mode.
Nov 20, 2009 | Jabra BT2050 Bluetooth Headset
Jabra JX10 Bluetooth doesn't/won't charge
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
Aug 22, 2008 | Jabra JX10 Bluetooth Headset Headset
Jabra BT 5010
I have the same exact problem... I went to the shop and replaced it and again the new one doesn't charge. F***** jabra did anyone tried to call the jabra support about this ?
May 09, 2008 | Radio Communications
Jabra a 210 adapter not charging
I contacted Jabra and they said this problem is due to a bad internal battery. There is nothing that can be done to fix it. So I returned it to the guy who sold it to me and got my money back. Purchased another from a different vendor, and this one works great. That's the only solution!
Oct 13, 2007 | LG Jabra A210 Bluetooth Adapter for...
Radio Communications Logo
3,066 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Mosaub Al Masri
Mosaub Al Masri
Ekse
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
