Averatec 1000 Notebook Logo
samson sanni Posted on Dec 08, 2011
My screen is cracked when i plug it up to another screen its still does not show it comes on but no picture on either screen
The screen on my zeepad jellybean 7.0 cracked how do i know if i need a new lcd display. I already purchased the digitized touch screen replacement
tha't an easy task to handle
See the pictures below
if your whole screen shows an image and the cracks are in front of it then its just a cracked digitiser
if you dont see the whole image and tyou see horizontal and vertical line or an image like spilled liquid then your Lcd is also cracked too
92dabd2f-7f4a-4795-976d-d97d7e32fa0e.jpgthis is a broken Lcd (the screen is distorted by the lines or no picture at all)
83952950-d5b2-47e3-b228-81f41d0190af.jpgthis is just a broken digitiser (the screen below the broken glass works fine )
hope that was helpful
My TV fell and the screen is cracked. The light comes on but no pictures
SORRY, if the panel (it is called a display panel) is damaged this is the end of this set- fatal from a cost point of view as the part if available will cost more than the set did when brand new.
The display panel in all these sets is fragile as you have discovered--even a minor hit can destroy the panel.
SD TECH
My Nikon coolpix touch screen is nearly new, it was a gift and worked for only 2 days. Now when I turn it on, and there is what looks to be a crack against a white screen. There however is no crack on the...
If it looks like a crack, it is a crack. You may not feel it because the internal screen is protected by an outer screen. Pressure of some type is usually the cause of cracked screens. This is an expensive repair.
37" full hd philips tv screen cracked because
If there is picture in the TV then probably it is the protective screen that has cracked and not the picture tube.Please check carefully.
2answers
My lg 42 in HD TV screen broke ,so is not showing anyting
is the screen cracked? if the screen is cracked, then probably that is the reason why is not showing the picture. if the screen is not cracked or has not been accidentaly damaged then we can try to troubleshoot
2answers
How to troubleshoot a video camera when the LCD screen is dark or has no display, in a Sony handycam DCR TRV22E mini
If you see correct picture in Eye Piece view finder but dark picture in LCD that shows problem with connecting flexible wire between LCD board and Camcorder main board. It got cracked/ damaged or broken after some time due to open/ close of LCD in its position.
Replace that flexible wire and problem will be solved.
Post back further question if you have any.
Thanks.
Screen on dynex tv is cracked at bottom and does not show picture but comes on.can it be fixed?
HELLO
It's the same old story with LCD screens. If it is damaged or cracked a repair will cost you the same or more than a new TV to have an LCD panel replaced. The only answer is to buy a new set!
SORRY! That's how it is! (:-(
2helpful
Screen broke, when i turn it on its white with splotches
You must change your screen for an new one!
If you can't find one send an email to Rotronica in the Netherlands they can provide one for you.
Broken plexiglass tv screen
crack in the screen? well the screen is the end result of small light mirrors and a color wheel that can project up to and more than 16 million colors ...... so that screen is very important to recieving these light shows and making a nice picture. a crack ... yes you will see all kinds of crazy things... and even probably on your wall behind you.
need new screen and problably a nice check on alignment.
Top Averatec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
