Dryers Logo
Debbie Williams Posted on Dec 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kitchenaid dryer model#3401724--Where is reset button for the thermastat on this dryer
Need to find the reset button on my dryer
Jason Kennidy
Level 3:
  • Master 1,344 Answers
  • Posted on Jun 05, 2012
Jason Kennidy
Master
Level 3:
Answers
1344
Questions
0
Helped
370200
Points
4021
There is no reset button on the dryer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
1 Related Answer
Anonymous
  • 82 Answers
  • Posted on Oct 06, 2009
SOURCE: kenmore, model#96589210, was running but not
you need chek door switch is conected.
Where is the reset button on kitchenaide
What is your model number? There is no reset button.
1helpful
Schematic diagram reset
There really is no reset button for this style of dryer. If you were to post what the situation is with the machine I'll be more than happy to help
Kitchenaid dryer model #3401724
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. In some cases the ignitor or the gas coils will go bad. Here is a good process of elimination.
1)Verify that the thermal fuse is good. If you don't have a meter bypass it and turn the machine on. If heats, thermal fuse is bad, if not leave connected and continue
2)When the dryer starts and thermal fuse bypassed, the ignitor should start to get hot and glow, if your thermal fuse is in the back you are going to have to have to the top of the dryer up to see down inside near the front for the glow. You can do this by taking the lint trap out and removing the two screws and popping the top up. If the ignitor comes on more than likely the gas coils are bad and if it doesn't the ignitior is bad. (this is while the thermal fuse is bypassed so the ignitor has power to it regardless)
3helpful
2answers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
3answers
Maytag Dryer Has No Power
i am sorry to hear this, mdg model number means that you have a gas dryer, you have a fuse and thermastat that needs to be replaced which is beneath the top behind the drum, you will see a short element, a blue thermastat and 2 white wires that goes down to a fuse.
when you buy the fuse, it comes as a kit, the thermastat and 2 fuses, one of the small fuses you will not use because one if for an electric dryer, so look at your fuse and notice a dot, i do believe your dot will be yellow...
so lift up the top and you will see these parts
Kitchenaid gas dryer had a pair of gym shoes in it and one of them got jammed and stopped the whole thing. Now it won't do anything when the start button is pushed. Is there a reset in this unit?
if it jammed then it might have damaged the motor. There is no reset other than a motor overload protector that cutspower to the motor if it gets too hot. When the motor cools down if might restart
Top KitchenAid Dryers Experts
Virgil Watts
Mike Cairns
Mike Cairns
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
