I have a Tview D7905B-D It can pull up every screen except the actual dvd screen. When I put in a cd or dvd I keep getting the warning screen. I have all the wires hooked up properly. I even have the brown hand break wire hooked directly up to the direct ground. how do I get it to play?
Try pressing the reset switch. If there is one, it will be a depression about the size of a pencil tip and will not be marked. If there is no reset switch, try disconnecting power to the unit for a couple of minutes.
If that only happens with one specific DVD, the problem is that DVD. Try playing it on another DVD player and see what happens.
If your TView won't play any DVDs, try turning the power off, blowing some compressed air into the unit, and turning the power back and see if that makes a difference.
Hi there, you have to go BIOS set up first. From there you have to select the first bootable drive is your CD/DVD rom in place of your HDD drive. Then save the setting and restart the PC npormal way.You will see the PC reading your disk & ask for press any key to continue for booting. I home its helpful for you. Thanks.
THE S-VIDEO LOOK ALIKE IS ACTUALLY A PIN ADAPTER FOR AV JACKS. THE DVD MAKERS USE SPECIAL CONNECTIONS TO COMPLICATE ADDING TO MIXED SYSTEMS. (THEY WANT YOU TO BUY ONLY THEIR PRODUCTS!) REPLACEMENT ADAPTERS ARE AVAILABLE ONLINE @ http://www.tview.us/
hi hallow then their is a problem in passing power supply or receiving power supply r some where the connection may lost which unknown to u so please refer it once again and see the battery connected perfectly are not. u explained u r problem very well but such problem can solve by cheaking the instrument practicaly so if still u r problem is not solved its better to consult the expert near to u directly
