When booting up my windows is loading and then my screen goes black and come up with an error: recomended resolution is 1280x1024... how do I fix this?
Most probably your computer has a higher resolution or refresh frequencies set in Desktop Settings than supported by the monitor. It might be also, that you have previously installed a monitor driver for a different monitor model, and the computer is using resolutions and frequencies supported by that previous monitor, with which your new one can't cope.
The solution would be to boot the computer in safe mode (hit F8 key when the computer is starting, you can hit it a couple of times, until you see a menu; choose "Safe Mode" and hit Enter).
Go to Desktop Properties, change to Settings tab, and click "Advanced" button. In the new window choose "Monitor" tab and change the monitor to "Plug and Play monitor". Click OK to accept the settings and close both windows.
Now reboot the computer - it should start with a rather low resolution, but the picture should be visible. Now you have to go to your Desktop Settings again, Advanced tab, and move the resolution slider to position 1280x1024. Accept and enjoy.
If the computer still doesn't boot, go to safe mode again, go to Control Panel, System, Hardware, Device Manager, drill down to Monitors, and delete all the monitor devices installed. After a reboot, system should start up and find new hardware, and install Plug and Play monitor. Set the optimum resolution of 1280x1024 as written before.
