Recently my KitchenAid Superba double oven control panel has been resetting/rebooting itself, and then gives the PF power failure message. It has happened three times, all shortly after the oven had been used and turned off. Message can be cleared and all seems to work fine the next time, but I'm wondering if there's a loose wire or short somewhere in the unit.
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
SOURCE: GE Profile F7 Error Code
I'm not sure what your problem is, but I have the same one. My stainless steel glass top model ?? is beeping all the time with error f7 on all the 4 tem control readouts. I'm guessing this is your problem as well. By turning the temp knobs it will stop, but sometimes restarts later for no reason. Other sites mention a ribbon cable on the touch controls (if yours has it, mine does ) that must be cleaned with rubbing alcohol. You turn off the power, and after unlocking the cable you clean the contacts with an easer and a q-tip w/rubbing alcohol. I don't know if this works but I might try it as the beeping is driving me crazy! The service techs will try and sell you about $450 in parts to fix the problem. This problem apparently has plagued these units for almost 10 years. Seems heat makes the cable get shorts at the contacts.
I HAVE NOT TRIED THIS YET so beware, but I had a short in my microwave and the site helped me fix a $500 control board for about 15 cents ( jumped a short on the board with a small wire!) Hope you get your problem fixed.
SOURCE: kitchenAid Superba
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209753620.pdf
Apparently it's not a Kitchen Aid, it's made by Whirlpool: kgst307hbs0
SOURCE: Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
SOURCE: Kitchenaid superba 27 double oven clock - can't change the time!
I went to the website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203177060.pdf
http://www.kitchenaid.com/custserv/service.jsp
from page 8
Turn the knob to the left until a tone is heard and "time" appears in the display window. The previously set time will appear in the display window.
Continue turning the time knob in either direction until the correct time of day appears in the display window
Press the START button to begin clock operation
