Question about Eclipse CLD2 MP3 Player
My eclipse MP CLD2 was reformatted and now will not turn on. Is there software I can download?
When the message to reformat the player popped up I said yes. Is there any software I can download to fix this or is it totally lost?
Posted by Noel Sevilla on
Anonymous
    New Friend:
How do you reformat your mp3?
Posted on Jan 05, 2012
5 Related Answers
Anonymous
SOURCE: reformat
Plug the mp3 into your computer, open your "my computer" folder and click on the drive your mp3 is plugged into. right click the mp3 icon and click reformat. should fix it but it will get rid of anything on the mp3
Posted on Jan 16, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: incorrect format
The songs that you loaded onto the player are not in the correct format - iTunes, DRM-encrypt. WMA are not allowed, for instance. Convert everything to mp3 format. It is asking you to reformat the player because it wants you to delete the wrong-formatted songs off the player. I would check your user manual to find the best way to reformat.
In general, though, there are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jul 06, 2008
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: how do I delete songs?
Deleting Files,Pictures,Videos,Audio
Books, etc. from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that
you do not want this will highlight the files/songs you do not want,
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please rate me,
Thank You
Posted on Mar 27, 2010
Anonymous
SOURCE: Short Life Battery Eclipse CLD2 (2 GB) MP3 Player
my instructions don't mention charging the battery, am I missing something? RFR [email protected]
Posted on May 28, 2010
Anonymous
SOURCE: How can I bring DOWN the volume (on my Eclipse
press the volume buttom, then press the left button(the same button which you can go back to listen to previuos track <<| )..make sure that vol is highlighted on the screen of your clip in mp3. Once volume is higlighted just press right " |>> "button to increase volume or the " <<| " to decrease volume...
Posted on Aug 18, 2010
Won't load menu and stays on Eclipse screen. Drivers will not load and none are available to download from website. How can I retrieve my music and folders off of it? Please help! Thanks!
I'm afraid your Eclipse died. There is no way to download anything, no way to listen anything, you can't even reformat it. Grt another brand, never buy Eclipse again!
How do I reformat my Eclipse MP3 player and delete all songs
My eclipse mp3 of 4gb won't turn on. But when I connect it to the laptop it works just fine. And it seems it won't charge either. What do I do?
9helpful
2answers
How to operate a eclipse mp3 player
Hi cindy22258...
Go to the following webpage and download your FREE eclipse CLD2 user manual
It will tell you the complete operation of your MP3 player.
Please take time to rate me thumbs up
http://static.highspeedbackbone.net/pdf/Eclipse_CLD2-manual.pdf
I downloaded plenty of music on my eclipse cld2 mp3 player an it reads on my compuer media player but i cant find out how to play it on my mp3 player its getting really irratating please help!!!
MP3 players can only play music that are in mp3 file format. If you copy music files to your MP3 player that are not in this format then the MP3 player cannot play these music files.
To convert/rip music files in mp3. file format, please click on this link and follow my instructions :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
12helpful
How do i turn up the volume on the eclipse cld2. there is no + or - just a vol. button?
Press and hold the volume button, then while still holding the volume button press the back arrow button to decrease volume and the forward arrow button to increase volume.
3helpful
Eclipse mp3 player says "no file"
I had the same problem. I think most files that itunes uses are in a .m4a format. The eclipse mp3 player will need all the music files in an .mp3 format. The eclipse actually has a "software" folder that includes the "replay converter" that will convert these files for you - or you can download any number of freeware that will convert the files as well. Once I converted those files, my eclipse played everything. Prior to that - even though I had synced everything with my Windows Media player, I was getting the "No Files" message. Good Luck!
2answers
the battery was overcharge, and might be too old (more than a year old?). Replace the battery with the new one
Digital music player (Lexor)
It sounds like a firmware issue. Send an email to [email protected] and they will email you back a fix.
Eclipse CLD2 MP3 Player Logo
Top Eclipse Audio Players & Recorders Experts
Ekse
Joseph Hoffmann
Oloyede Monsuru
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
