SOURCE: Nikon D50 autofocus
I just encountered the same problem. The advice giver who forced the focus ring with autofocus engaged was right on the mark. (Thanks!) Actually, I didn't need to force it, just gave it a firm push. Voila!
SOURCE: Nikon D50 LCD Display does not work
NatD, The D50 and indeed most SLR digital cameras [ I have a D40 ] does not allow you to take pictures using the LCD display ... this is by design, you are meant to use the viewfinder and the image you see through it is straight through the lens via a mirror block [ called a reflex pentamirror or prism ]. When the mirror is down such that you can see the image in the viewfinder it is obscuring the sensor [ the bit that takes the picture ] and when you take a shot the mirror lifts and the picture is recorded. Its this reason that DSLR's dont use the LCD to shoot, however there are a few now available that do let you do this, such as olympus, new panasonic one and higher end Nikon and Canon cameras. Hope this explains it without getting too detailed!
SOURCE: How to Fix D50 Nikon flash shutter and light not working
please i want u 2 send me free digital camera
SOURCE: Nikon 18-200 autofocus lens won't
OK I just fixed it, thanks to Ken Rockwell.com who says:
"Once in a blue moon my Nikon 18-200mm won't focus on my D200. Manual focus works fine, but the lens won't autofocus no matter what I do. It's annoying!
Of course the camera needs to be pointed at something with contrast, lines or texture. Point it at the sky and nothing autofocuses. That's normal.
One time this was so bad I thought for sure I was going to have to send my lens in for service, since nothing would get it to go.
Then I discovered the problem: I had knocked the AF switch on my D200 to M. This switch is easy to knock and I had forgotten to check the obvious. There also is a switch on the lens which is not easy to knock, but I have left the lens set to M shooting at night, and I forgot to return it to A/M the next morning.
This fixes most of my problems.
Rarer is when the lens honestly won't focus. When this happens I turn the camera off and on. If this doesn't fix it, turn the camera off, press the lens release button and rotate the lens back and fourth a couple of times. This will clear any dust off the electrical contacts and focus returns."
SOURCE: Pictures taken all come out black
CCD FAILURE!
Call NIKON for Free Repairs it is a known manufac
fault in thousands of cameras , dont worry just call them see this for
info on this problem
Kindly Rate me WELL !
this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
