Have you checked the filter and does the machine spin but not at full power they will not opperate propperly if you have a blockage alot of machines suffer problems like this because the waste water will not discharge due to blockages in the pump/ filter/sump hose, and if the waste pipe is connected to the sink waste they will block there try these few things first make sure all your water is discharging if you still have the same problem let me know.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
