SOURCE: Control lock light on.Pressed Pressed
May I get the make and model # to help you remove the Control lock
SOURCE: My dishwasher DU1050 is stuck on Lock and I've
Hi! cccole
Dishwasher may be in bind. remove kick plate and make sure adjusters are not putting case in a twist, or pressing unit to tight to top of cabinets.
InMrFixIt.
SOURCE: I can't get the control panel to reset. The
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
SOURCE: My VZ9996U1 built-in dishwasher won't lock &
sounds like the door latch is broken, turn off power to unit and remove in side of door, about 20 screws, at th etop of th edoor you will see the latch it will have several wires going to it, you may even find broken parts (PLASTIC ) you can order parts from here http://www.appliancepartspros.com/ they have very fast shipping you just need all the info on the machine
SOURCE: detergent door won't close, dishwasher won't start
Contact a professional technician to see if the spray loaded action needs to be replaced with a new cup area.
