Is it my element and if so can I fix it or do I need an electrician?
SOURCE: fan oven element not working
getting a shock just means that live is connected. if no heat, that means that no neutral assuming element is ok. do you have a multimeter so you can check if live and neutral present at element? are you sure old element was faulty as it seems strange that putting in a new element did not cure problem i have a memory that there may be a fan fail stat mounted close to the element. worth a check
SOURCE: Left hand oven not getting hot!!
If there is a low flame then the chances are the mercury flame protection device is broken. This is a safety device that protects the cooker from allowing full gas flow if the flame fails. However if the switch is broken then it won't allow full gas on to the burner. Hence a low level of burner which does not get very hot.
SOURCE: warmer lights up but not getting hot - Rangemaster Toledo XT
Hi Sally
I havd exactly the same problem. I contacted Rangemaster/Aga support line (0845 603 5312 if in warranty, 0870 789 5107 if not) and they told me the heating element was shot.
My cooker is 2 1/2 years old, so out of warranty, but they were good enough to send me a new cooker top (top left hand side only of course) free of charge!!!, I just have to get it fitted.
You have to replace the whole left hand side of the cooker top too - the burner that the wok goes on!
Good luck
