Question about Sunbeam 805810 HeatSense Heating Pad Heater
Instruction manual for sunbeam model 809 heating pad
Posted by Charlie Fortmuller on
Dick Snider
    President:
  • 742 Answers
Hi, you should be able to get the manual here:
http://manualfox.com/link/sunbeam.htm
Posted on Dec 10, 2011
Sunbeam heating pad model 828-511 is showing F2 on controller
Hello, Pat -
I can only find that the F2 error code means there is "a problem;" not what the problem is.
I suggest you go to this Sunbeam web page for your model of heating pad:
http://www.sunbeam.com/pain-relief/back-and-spine/sunbeam-microplush-body-shaped-heating-pad-with-digital-lcd-controller/000828-511-002.html
You should see a link for "Live Chat" on the right side of the page. Click or tap on "Live Chat" to text with a Sunbeam Customer Service Representative. He or she should be able to explain the F2 error code and what can be done to correct it.
Best wishes.
Mar 07, 2018 | Office Equipment & Supplies
I have a Sunbeam model 970 heat pad. I plugged in and controller just reads F2....I can't find any instructions or know how to fix. Can you help?
Hello Carrie,
You may be able to download an instruction manual from Sunbeam directly here: Instruction Manuals at Sunbeam com
Otherwise, you might need to use their contact us feature and ask directly.
I hope this helps!
Feb 11, 2018 | Sunbeam Heating & Cooling
My express heat king size heating pad worked great for two months now it just flashes the f and won’t heat up can’t return it because was a present and they didn’t keep receit
Hello, Trish -
I hope I am correct in assuming yours is a Sunbeam King Size XpressHeat heating pad. If so, if you do not have the instructions for using the heating pad, this is a link to a PDF document with the instructions:
http://www.sunbeam.com/on/demandware.static/-/Sites-sunbeam-Library/default/dw269358cc/documents/instruction-manuals/000832-915-001_43_90483985.PDF
On the first page of the instructions (PDF document), column 2, at the bottom of the warranty information, under the heading How to Obtain Warranty Service, you will see the telephone numbers for USA and Canadian warranty service. I suggest you call the relevant number and find out if someone in Repair or Customer Service can help solve the problem.
Jan 12, 2018 | Heating & Cooling
Sunbeam SFP 809 operating instructions
similar instruction can be found at https://www.sunbeam.com.au/Root/Specifications/InstructionBooklet/LC6250_ib_1.pdf ...i hope it help
Apr 13, 2014 | Sunbeam Food Processors
I need instructions on operating a remote to Sunbeam,Cal-King, electric mattress pad.
Which model Sunbeam mattress pad do you have? Sunbeam has some of their manuals here: http://www.sunbeam.com/manuals.aspx . The electric bedding share a manual. The direct link is http://www.sunbeam.com/BeddingManuals/SunbeamBedding/Universal.pdf .Make sure that you are using the master control for your side of the bed (that's the one closest to the plug for the wall outlet).
You may need to turn on the second control and set it to 0 at night. If you still are having a problem with the heat being uneven, you might need a replacement mattress pad. I know we've replaced several electric blankets or mattress pads due to problems with the control/uneven heat.
I hope this helps.
Jan 25, 2012 | Heating & Cooling
Get F2 error code on sunbeam heating pad model cat93, contrller sw404
Crimped the ends of the heating pad cord where it attaches to the pad a little then did the plug and unplug three times while holding down the on-off button and that did the trick
Jul 03, 2011 | Sunbeam 805810 HeatSense Heating Pad...
Sunbeam heating pad no longer heats. The red
I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
Jan 12, 2010 | Kitchen Appliances - Others
Sunbeam 805810 HeatSense Heating Pad Heater Logo
971 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
