No!!!!...Yes!!!
No, the sending unit is working right.
Ideas? Yes, I think the problem is the water pump. Don't drive it overheated till you get a new water pump or have it inspected. You say it's a small leak where it bolts to block, but maybe it's the "weep hole" on bottom of pump leaking, meaning the internal seals on the pump have failed. If so, it won't be a small leak, it will leak all the time engine is running. A lot may be swept away by air, or by evaporating. Check it out. That's a likely cause of overheating.
Testimonial: "no!!!! not weep hole,and leak is at gasket very small leak been under car and checked...any more ideas???tks,. "
You need to replace the gasket between the pump and engine block to stop the water leak/coolant. Losing coolant will cause the engine to overheat.
