A AOSS is a checkpoint for your wireless intrenet that gives it the wireless signal a boost for a longer range. Try doing a running the internet connection set up again and see what strength if any your modem/router is putting out for your PS3 to detect.
AOSS is a one touch system on wireless routers, basically if you have a wireless router with AOSS you can simply press and hold a button then connect to the router. You need to press scan and look for a wireless router that way. Here is a good tutorial for connecting to the internet.
hope this helps
chaque battery of wireless KB. ok than refix USB port if it blue light is blenk ok, than back Side of KEYBOARD & MOUSE u have found one blue botton this botton press Same time press keybord button it will conect ok. the blue botton press only 5 Second
go to system settings, go to internet (page 3), connection settings select a connection (1,2 or 3), search for access point, choose your access point. For Aoss, go to a connection (1,2 or 3) tap Aoss, push the Aoss button on the access point until the light flashes (P.S you need wireless internet or Aoss)
First, make sure you have wireless internet, than go to system settings. than internet.
For AOSS:
tap connection settings
tap a connection labeled none
tap AOSS
press the AOSS button on the access point until the AOSS light flashes
tap ok to preform a connection test
For access point:
tap search for an access point
tap the desired access point
(note: if you are using a secure access point, enter the key and tap ok)
tap ok
tap ok to preform an connection test
The aoss button is not on your psp Its on your stick, hold down the left on your stick. <> It will start blinking. if you dont know what i mean still.There are to lil simbles on your left of the psp They are very small. up just a little bit is a stick.sometime you use the stick to operate your game.(move) Click the left of it. If you dont get that then your ******* stupid
