Kenmore 24032\24036 Top Load Washer Logo
raymond doucet Posted on Dec 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 70 series washer leaking - Kenmore 24032\24036 Top Load Washer
Anonymous
Level 2:
  • Expert 333 Answers
  • Posted on Dec 11, 2011
Anonymous
Expert
Level 2:
Answers
333
Questions
0
Helped
131504
Points
783
Check the hoses underneath the tube. There is two hoses one from the tub to the pump then the pump to the drain. Probably loose hose clamp. Or could be the pump leaking. If it is the pump itself you need to replace it. Or also coould be the botttom seal in the tub where it connects to the transmisssion.
When does it leak? It also could be the inlet hose if it just leaks when the water is going in.
110.22954100 what is capacity of this Kenmore Washer
Kenmore 110 washer capacity
Washer. The Kenmore 70 series washer has a 3.5 cubic foot capacity. It comes with the Sears Triple Action agitator and can hold 28 extra-large t-shirts in a single load.
Kenmore Series 70 Specifications ' Hunker
What is the capacity of the Kenmore 70 series model#11022722101
In the Kenmore line of washers and dyers, the 70 Series is a mid-priced family appliance that handles an average family's laundry needs. All appliances in the 70 series are freestanding and do not have stackable units. Available with both English and Spanish instructions, this mid-line series of appliances is suitable for almost any household needs. Kenmore Series 70 Specifications eHow
1helpful
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Kenmore series 70 squealing and leaking water
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your pump is bad.
See the following illustrated description of how to access and check / replace the pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=8eaba8b07483055c9c0f23bd2274f0a8
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
2helpful
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
11helpful
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kemore 70 series
Its possible that your trans. is going to need replaced. Maybe have some bad seals on the trans. As far as the water leak goes. Could be a tub seal, maybe some worn inlet hoses, maybe a leaky inlet valve.
We hope this gives you a start on your appliance repair. Anymore questions please feel free to reply back.
Alexander
vince
