Cell Phones Logo
Posted on Dec 04, 2011
When I turn on my nokia says contact service - Nokia Cell Phones
Anonymous
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Dec 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
3699
Points
47
What is Your Nokia Mobile Phone model?
You can unlock the Nokia Phone from Network Lock,Because if the Phone says Contact service provider or contact service means it locked to Network,Find the Network,Country it Locked ?and unlock it..... Get the unlock code for Nokia GSM Network locked Phones at here Onlinegsmunlock.com/nokia/rs7wp8/
and Unlock it.
Conatact service shown in my nokia 5310expressmusic
My Dear Brother:
Flash The Phone With Latest softwear Version
Contact service problem will Quickly Solved
OR:
contact service center And Hilp the Service Oprator
3helpful
2answers
When ever i turn on i get contact service and my
Hello Sir, This type of message is seen when the network provider of your phone have blocked your sim from their respective network or they have stopped giving you their service. In this case you have to contact the service provider of the network to get the service back.
Thank you Sir, Have a nice day.
9helpful
2answers
Nokia 6300 White Screen Contact Service
one solution is to reflash your phone memory, other than that is a bit more complicated, it may be phone main processor, water inside, or power source, try to find a mobile phone service
"Contact Service"?
Hi heyitskacy,
The solution for your problem is described beloe....
My phone displays "Contact Service"
The message ”Contact Service” indicates that there may an internal problem with the phone. The following steps may help resolve the issue or give some indication as to the source of the problem:
  • Remove and re-insert the battery according to the instructions in the user guide.
  • Remove and re-insert the SIM card according to the instructions in the user guide.
  • If your phone has a memory card, remove and re-insert it.
If your phone still displays the message, please take it to the nearest Nokia Care point for inspection. You can find service centre addresses from the drop-down menu at the bottom of Repair.
Alternatively, if you wish to send your mobile phone to our Freepost address for repair, please download and fill in our Freepost Repair Form (62KB PDF file requires Adobe® Acrobat® Reader®). Then package the phone and your completed form in a robust, padded envelope and send to the address on the form.Please note: the freepost service is for UK customers only.
Where is my nearest Nokia Care point?
You can find Nokia Care point address and contact information from your local Nokia Web site: select your location from the drop-down menu at the bottom of Repair.
How can I contact Nokia Care services?
You can find Nokia Care services contact information from your local Nokia Web site. In most cases, customer service is offered via email and/or phone.
To be directed to the Nokia Care services section of your local Web site, select your location from the drop-down menu at the bottom of Contact Us.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
I have a nokia 6133 and it wont turn on
you may need a new battery, if so do as it says. contact the service.
Contact service
contact service, i have a nokia phone too and its says when i turn it on,, contact service, the only thing that i did is to relash the phone and change the imei,
Aug 29, 2008 • Nokia 7250i
"contact Service"
get it to service center if warranty is available or use nokia update service if available for his phone.
main thing make a flash to your mobile it will available in mobile service shops...it takes around 5mts to do that..and ur mobile ill normal
66helpful
6answers
Nokia 2626 contact service
SOLUTION NOKIA 2626 CONTACTE SERVICE
Jan 27, 2008 • Cell Phones
2helpful
5answers
Contact service
Maybe the hardware got wrong. Better u try to reset the software by restore factory setting. def password : 12345
1helpful
2answers
Nokia 3220
the system of your phone maybe corrupted, the reason behind it is maybe you have fulled the memory, the contact service fault has two causes its either software failure or hardware failure, you should try first the software reprograming, you need tools, second is hardware, your phone serial no. maybe corrupted so the program is close you need to replace UEM IC, if theres a fualt withis IC it shows contact service.gud luck
Jul 02, 2007 • Nokia 3220
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
