It Ran the whole night and only stopped when I opened the door. Now if I close the door it starts on its own
SOURCE: GE Monogram
The control module is damaged and, you will need to replace this device asap. the pump will burn out soon if the control module isn't replaced.
The control module will run you about $109.00
SOURCE: GE Dishwasher GSD2000 door latch/sensor malfunctioning
The latch could need a simple adjustment or may require replacing.
Is the catch (the part that sticks out of the dishwasher, not the door part) loose?
Maybe try to loosen it (dont unscrew it completely) and re-adjust it to suit.
Hope this helps!?
SOURCE: I ran my dishwasher last night and woke up to a
This sounds like a bad relay or contactor that feeds power to the element. Opening the door most likely cuts power to the entire system. When the door closes, power is going through a relay that is stuck, allowing power when there should not be any. Follow the power line from the element back to relay that feeds it. Hopefully this will not be your control board. Relays are cheap and easy to replace. Computer boards are not. Good luck
SOURCE: GE MODEL 5900N10BB. TWO
Hi. I am actually having the exact same problem. Anyones help would be greatly appreciated.
Thank You
