SOURCE: Error 51A2: System cover has probably been opened
I would say you probably need to update the firmware. That should clear any issues you have with the event log
SOURCE: power won't turn off
The Green LED on the power board is a warning light to techs to let us know the board is energized and to wait for it to go fully off before changing RAM or anything else on the motherboard. So, ignore that light.
What surprises me is that there are no error beep codes.
Try this out, pull the plug and wait for the light on the motherboard to go off. check that all connectors to the motherboard are tight and all plugs from the power supply are tight, remove and re-seat the graphics display adapter.
At the bottom right of your motherboard is a set of wire connections that are of mixed colors, green and white, red and while, etc. See if the green and white connector and all of them are seated correctly. It could be that the wires from the power on button are not seated properly or have come loose. The power on connector is usually three pins wide but has wires at either side of the connector. Also, some PC have a Case Open Switch, it is usually noticeable by examining the case opening. If you see one, put the case cover back on and try again.
Frankly, it appears your machine is stuck in sleep mode where even removing the power plug does not fix the problem.
The confusion on this problem is that there are no beep codes, and the board is energized which won't happen if the Power Good signal from the Power Supply is absent and thus preventing a bootup. Since, it is energizing the problem may be any of the above I suggested you look at and possibly your motherboard's CMOS chip. This chip instructs the board on how to boot up to the point where the BIOS chip can take over.
Hopefully, you are under warranty and can get service from the maker if nothing can be resolved by our help here at fix ya. Or, if you don't consider yourself a computer tech I'd further suggest you have one get their hands on your machine where diagnostic can be more thorough than we can give you via text messages.
Still, try the above suggestions and let us know.
Thanks,
Worldvet
SOURCE: PC keeps freezing on boot up
Let's narrow the problem down a bit. The biggest clue will be "where" it hangs in the boot process.
1) During (or before) the POST (power on self test).
This would signify that you have a hardware issue. Often, the system will beep at you, and you can decipher those beeps to figure out the problem. Some things that will cause a freeze here are your video card, RAM, the CPU, or even a fan (especially the CPU fan).
a) Video - if you are seeing anything on your monitor, it probably isn't video. If not, replace the video card (if using the onboard video, add an outboard card. If using an outboard card already, then swap it out with another one, boot, and see what happens.
b) RAM - swapping out chips is the only way to test it, unfortunately.
c) CPU Fan - Eyeball it and see if it is spinning. A fan failure will instigate an immediate shutdown, to prevent the CPU from burning up.
d) CPU - Another tough one. The only real solution is to replace it with another one, and see if the system boots.
If it seems to be none of the above, it may be the motherboard itself that has an issue. Once you try all of the above, you can be more certain that it is indeed a bad board.
2) During Windows startup.
This would mean you have a Windows problem. Often, a new driver or some new piece of software can alter things enough to cause a hang. Attempt a boot in safe mode (which loads only default drivers), or even restore the OS to an earlier point. If you get a BSOD (blue screen of death), you'll want to look for the error code on the page, as it will at least give you a clue as to where the problem is. Another option is to boot from the Win Install CD, and effect a Windows repair. This will fix an awful lot of problems.
Cheers
Nick
SOURCE: ASUS p5vdc-MX motherboard won't boot
The light is probably the power light which is ok, but from past experience it sounds like the board is dead for one reason or other. Is it still under warranty? If it is take it back to where you got it, with the purchase docket if you have it and talk to them about what you have tested and ask for a replacement. If it is out of warranty, try ebay or use www.staticice.com.au to search for the same motherboard if you want to rebuild the system without having to reload windows.
SOURCE: Where is cmos reset jumper? Is it near battery,
Try
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_Aspire_M5640_M3640M1640_BOOK_VerC.pdf
page 77
label CLR CMOS 3 pin type 1-2 clear 2-3 normal
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
hope this helps dont forget to vote!
Generic BIOS / CMOS passwords
Try using generic CMOS passwords. A complete listing of these passwords can be found on
document CH000451.
Use a BIOS password utility
There are utilities designed to help bypass CMOS
passwords. An example of a great utility to decrypt / bypass BIOS
passwords is the
PC BIOS Security and Maintenance toolkit, which is available by
clicking here.
Clear using jumper (recommended)
Precaution: When inside the computer please be sure you're
aware of the potential damage that can be caused by ESD.
On the computer
motherboard locate the BIOS clear / password
jumper or dipswitch and change its position.
This jumper is often labeled CLEAR, CLEAR CMOS, JCMOS1, CLR, CLRPWD, PASSWD, PASSWORD,
PSWD or PWD as shown in the picture to the right. To change the jumper simply
remove it from the two pins its currently on so that it covers the pin that is
not covered. For example, in the picture to the right pins 1 and 2 are covered,
you'd remove the jumper and put it on pins 2 and 3.
Once this jumper has been changed, turn on the computer
and the password should be cleared. Once cleared, turn the computer off
and return the jumper or dipswitch to its original position.
The location of the jumpers or dipswitches are dependent on the
manufacturer of the computer and motherboard. However, below are some general
ideas on where to find it. Remember that most motherboards could have dozens of
different jumpers, make sure you're changing the CMOS jumper and not something
else. If these general suggestions do not help refer to your motherboard /
computer documentation or skip to the next step.
Removing
the CMOS battery like the one shown in the picture to the right will cause the
system to loose all CMOS settings including the password. To do this locate and remove the
CMOS battery on the motherboard
for at least five-minutes. After this has been done put the battery back into
the computer and turn it back on.
Jump the CMOS solder beads
Older computers and especially older laptops don't have
jumpers
or dipswitches and require the user to jump a pair of solder beads on a
circuit
board. The identification and location of these solder beads can vary
and if not available in computer documentation is only obtainable
through the computer manufacturer.
If you've identified the solder beads they can be jumped by
placing a flat-head screwdriver over the two beads and leaving it on those beads
while turning on the computer. Once the computer has booted turn off the
computer and then remove the screwdriver.
PLEASE ACCEPTT
Motherboard type is AOpen i975X a-YDG. The boot LED flashed red for a short moment.
