Nokia C3 Cell Phone Logo
Tracy Squires Posted on Dec 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant conect to 02 internet on nokiac3
Cant conect to 02 internet i have brought bolt on and can conect to wifi
Anonymous
Level 3:
  • Master 380 Answers
  • Posted on Dec 09, 2011
Anonymous
Master
Level 3:
Answers
380
Questions
0
Helped
102622
Points
1118
Go to menu->settings->connectivity->wlan->internet connection
Please check your phone sw version from this link and update if necessary.
Please do not forget to back up your phone before you update.
http://europe.nokia.com/support/download-software/device-software-update/can-i-update
The latest sw is 4.60 depending on the sales areas and variant.
Please also become familiar with the FAQs :
http://europe.nokia.com/support/search?comp=Nokia+C3-00&qt=wlan
How do I manage WLAN internet access points on my Nokia C3-00 device?
How can i use always WLAN connection on my Nokia C3-00 phone for Internet instead of GPRS?
I hope this helps.
First of all you delete all current settings, these are for 02 and will not work on giffgaff. To delete settings:
  1. Press the navi key and go to Menu
  2. Go to settings
  3. Go to configuration
  4. Press the navi key on Default config. settings
  5. On both 02 Pay&Go and 02 paymonthly press the backspace key (inbetween the p and enter key)
  6. Select Yes to delete on both
Now that you have done that you need to set up the giffgaff settings, I recommend using this method to do it:
  1. Go back to configuration
  2. Select personal settings
  3. Select Options then Add new and then Web
  4. Put the Account name to anything you want (I put Giffgaff web)
  5. Put the Homepage to anything you want (I put http://www.google.co.uk/)
  6. Put the Username to giffgaff and the password to password
  7. Put Use preferred access pt. to No
  8. Select Access point settings
  9. Put Proxy to Enabled
  10. In the Proxy address type 193.113.200.195 and select OK
  11. In Proxy port type 8080
  12. Go into Bearer settings
  13. In Packet data access pt. type giffgaff.com
  14. Put the Network type to IPv6 (IPv6 appears to be faster)
  15. Leave the Authentication type at Normal
  16. In User name type giffgaff and in password type password
  17. Go back until you see your Personal accounts and press Options on your settings and select Activate
  18. Go back again and in Default config. settings select Personal config.
  19. Finally press Default in all apps.
Now that you've done this set up the packet data settings:
  1. Go back and select Connectivity and then Packet data
  2. Put Packet data connection to When needed and select Packet data settings
  3. In Active access point select Access point 5 (Access point 1 is known to have some problems, select Access point 5 to be on the safe side)
  4. Go into Edit active access point
  5. In Access point alias type whatever you want (I typed in Giffgaff)
  6. In Packet data access pt. type giffgaff.com
Okay so finally for wifi settings:
  1. Go back and go into WLAN
  2. Select Internet connection to Ask first (so that you can choose to use wifi)
  3. Now select Available WLANs and wait for the search
  4. Simply find you WLAN, select it and enter the security password for it
  5. When it asks Save network for future use select Yes
Now you have giffgaff internet and wifi set up on your Nokia C3-00! For any issues you can message me, I will be willing to help!
Update: You may be experiencing problems with using wifi with the browser or any other application, do this to fix it: "I had the exact same problem. What I did was that I removed all network Internet settings, GPRS, WAP, etc. because I do not want to use them which is when I lost the ability to select which AP to use.
So what I did was I created a personal setting:
Settings > Configuration > Personal settings > Add > Web
Then go to the main menu > Internet > Web settings > Configuration Settings > Select the personal settings that you created
Now try to access the internet and it will ask you to choose, choose Wi-fi
Then go back to the personal settings and delete the setting that you created. From now on, you will be asked which connection to use everytime you access the internet
If you want to restore your GPRS settings, you can just request it from your network provider and they will send it to your phone."
Source http://discussions.nokia.co.uk/t5/Cseries/ANOTHER-NOKIA-C3-WLAN-PROBLEM/td-p/754515
My cell does not find a wifi conection
Can you make use of another phone and snap a picture of your phone's WiFi screen page/window and upload here please
However, if you can navigate to a WiFi connection menu/page, there must be an off/on switch you need to activate by swiping either right or left on your screen
Emachine wifi
try uninstall and reinstall the driver.
if it's the same, try with a new WIFI USB adapter.
mostly it's the signal issue if you still can't connected, try getting closer
My Ematic 7 4g wifi ebook reader can't conect to
just go to network setting and turn ON WiFi first, then make a search for the availebel networks
I cant use the internet when im out of wifi conections, i can speak but dont use the internet conection, what can i do?... my phone is a htc desire hd im from israel and dont know what to do for to make...
Thanks for visiting FixYa!
First, here's a link to the online User Guide for your phone in case you don't have one handy. Click here: http://member.america.htc.com/download/web_materials/Manual/HTC_Desire/100330_Desire_HTC_UM_WWE.pdf
Next, (and I apologize in advance for asking) but, do you have Internet (Data) service on your account with your cellular service provider? Data service is required to access the Internet. If you don't have Data service, simply call your cellular company and have them add it to your account.
If you have Data service on your account, see page 128 of your User Guide. It will explain in detail how to select the proper settings in your phone to get Internet service.
Feb 18, 2011 • Cell Phones
I brought the nokia c3 and then i went to youtube it said suscribe to packet data im on 02 free internet for a month
You have to have minimum of a GPRS connection if you want to access the internet from the phone. Or you should have a WiFi connection available. This is what the error msg means.
To do that please call up the helpline of your service provider and ask them to activate GPRS on your number and also for the GPRS settings for your phone model.
I tryed to get internet on my wireless internet in my wii before i tryed i did the test and it said error and then a whole bunch of numbers and now i cant get internet what should i do .
press the home icon on wii remote > go to configure network > select network 2 > go for access point selection > you must be able to see your wifi network there...
if you try to conect, it will ask for security key... Type your wifi network password and select done... It will ask to upgrade firmware if the connection test succeeded...
I have zyxel p-600 series router and i managed to connect to internet via cable (wired).then internet works on my ubuntu 10.04 but only when i write sudo dhclient in terminal. then internet works but i...
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
Wifi button won't work When I depress the wifi button it stays orange instead of turning blue.
Look by the clock.. on the start bar for a icon to conect
open it and makesure its on,, and then conect to you WIFI, try reseting your wifi router, try reseting your internet box
If you already know how to do all that with no luck,
check the drivers for the wifi card
Its ether not conected to a network, lost driver, wrong network setings or bad wifi card.
Brought a secondhand bodyworks gym set and cant work out how to hook up other cable to use other aplications of the gym
second cable dosent need to be conected to weights. it is bolted down to anchor other end of cable.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
