If you are asking for the Wi-Fi password, that is unique to the user who initially set it up. You can reset the router but following the manufacturer instructions and holding the reset button down in the back. This will erase all settings on the router.
If you can log into the router you should be able to simply reset the guest PSK to whatever you like. If you have a computer that can successfully connect to the guest network you can open an elevated command prompt on it and type netsh wlan export profile name="ProfileName" folder="C:\" key=clear Replace ProfileName with the SSID for the network.
It is not likely you will be able to recover the password if the individual who implemented it is unavailable to provide it. Your only alternative is to factory reset the device according to the manual and then put in the necessary settings required. The default username and password for this device is easily found in the users manual for the device, found here:
You can reset the Belkin back to the default settings by - Press and hold the pinhole RESET button with a paper clip then power uo the Belkin. Release the RESET button after approx. 15 secs then the router will boot up. Open up a browser and enter the Belkin configuration URL http://192.168.2.1 The default PW = blank (just press enter)
Logon to your router from your computer using your browser and going to http://192.168.1.2/. If it wants a username, the default username is blank and the default password is either blank or "password".
The Belkin management tool will come up. From there, go into your security and look to see if your passphrase is visible. If it is, you're good to go. If not, you can change it on that page save it and close out.
Don't forget to change the passphrase on any wireless devices you are using connected to the Belkin wireless router.
What is the brand of the router your using? This information will be from the router that you have. Use a wired connection from the router,check your default gateway (ipconfig) and type that numbers in your address bar. You will be able to access your set-up page, look for wireless tab and look for wireless security. You will see there your WEP key.
