Master
- Posted on Dec 03, 2011
Re: How do I check my hot water element?
1)Locate the upper heating element
in the top access. The heating element is above the thermostat, and all
you will see is a round disc with two wires attaching to the disk.
2)Set your ohm meter to the X1 or
RX 1 scale to measure the continuity of the heating element. Touch each
of the ohm meter probes to each of the terminal screws on the heating
element. A positive reading indicates a good element. If there is no
reading, the element is faulty.
3)Test for a possible short in the
heating element with the ohm meter. Touch one ohm meter probe to one of
the heating element terminals. Touch the other ohm meter probe to the
bracket that secures the heating element. If you get a reading of zero,
the element is good. If there is any positive reading on the scale, the
element is grounding itself and will require replacement.
4)Test the lower heating element exactly as the upper heating element.
5)Place the access doors back on the water heater tank, and secure them with the screws.
Good luck
E.CUADRA
