For SIM Rejected Error:
1. Error messages appears due to some reasons, it might be because the sim is faulty.2. You can test if the sim is working fine by using the sim to a different mobile phone.3. If the sim works with the different phone it means that the SIM card slot is the one defective, if it doesn't work for another mobile it is SIM card issue.4. You can also try power cycling the mobile phone by:*turn off the mobile and remove the SIM, memory card and battery*wait for 5 minutes before you plug back SIM, memory card and battery*make sure that the sim card is not dirty nor containing any dust or soil.try to check the copper foil of the sim card if it has dents.5. If this wont work,you need to check the availability of your account/account status/try to check if the card has been disconnected from your mobile service provider's BTS (need to call your mobile service provider for this information)6. Check as well from your mobile service provider if there are outages within your area or in the BTS where sim card is registered.7. You can also visit one of their offices and asked for a replacement of the faulty sim card (possible fees may apply), they have access providing you another SIMcard with the same number and they can retrieve the contact information of your friends saved in the SIM card.
Thank you for choosing www.fixya.com.If you have any other issues under the sun, just post your questions here and we will provide you the answer.
If the Phone says Sim rejected means it locked to Network,You need to Unlock it,you can get the unlock code from the site
Unlocking4u.com/unlock-your-phone/rs6wp2/ and Unlock it from Network Lock,Then You can use any GSM Network Sim card in NOKIA 1280.
SOURCE: sim card rejected / insert sim card
Unfortunately, they usually fault after getting wet. You might want to take it to a local repair facility and have them check the internal circuitry. Best of Luck.
SOURCE: my blackberry curve says sim card rejected
Such problem occurs when the sim or network provider of your sim doesn't support your phone. U might need to have your phone "Open lined". You have to make sure that the card using is new and is not from out of your country. Any other questions about this topic, just post it and will surely be entertained by me and other experts....Tnx, a rate from u will be much appreciated.
you may have put it in wrong because i had the same problem at first and realized that it went in totally different then any other phone i have had.
SOURCE: sim card rejected on nokia 2630
is it the same sim u used in setting the password? insert the original sim and change security settings to none
