Question about Sony VAIO VGN-NR285E/T Laptop
Sony vaio vgn-nr285E battery won't hold a charge
Posted by chrysteeb on
Elmi Abdi
    New Friend:
  • 3 Answers
The battery is finished you may used the battery inside to the computer with adapter so battery lost the charge so is finished and solution is to replace new battery.
Posted on Jan 01, 2014
Chris Hingee
  • Sony Master
  • 32,281 Answers
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Posted on Dec 03, 2011
Won't boot up and fan not running
Sounds like a dead battery or power supply or both...check for a light on the power supply to prove it's connected.
Jan 09, 2013 | Sony VAIO VGN-NR285E/T Laptop
Sony Vaio P Series Netbook shows its charging but stills stays at 1percent availabe almost 3hours
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 12, 2012 | Sony VAIO VGN-CR205E/P Notebook
I hadn't charged my Sony Vaio model PCG-61611L for a couple days. Then when I finally plugged it in to charge, it won't turn on. I even left it plugged in for a few days and still nothing. It has...
Try A Hard Reset
Remove the battery and charger/ac adapter/power cord from your Sony Vaio laptop, press and hold the power button for 20 seconds to discharge any residual current inside the laptop.
This clears your RAM and is like a hardware reset.
Replace the battery and charger/ac adapter/power cord
and turn your laptop on.
If that does't work try removing ram and reinstall. Sometime this works with these laptops.
Sep 11, 2017 | Sony VAIO VGN-AW330J/H Notebook
Hi, I have a sony vaio vgn nr285e running on Vista, the touchpad is very hard to respond & the screen keep tabing differnt fields on its own respectivly, All drivers are up to date ( I think ) what...
Could be dirty contacts. Sounds like the laptop needs to be disassembled and hit with compressed air. If you try to do this yourself look up a service manual for the brand and model # of your laptop as once you take it apart you have to completeley reassemble it the same way:)
May 28, 2011 | Sony Vaio VGN-NR285E/T Computer PC...
My computer won't charge! The problem is that where i plug in the charging adapter that "little hole" is loose and won't keep the adapter in, ultimately not letting it charge
This is really a physical damage to the slot for the plug.
There are some tweaks that you might try to keep it there, like pushing it and holding it with something, or use scotch tape or something similar, but ultimately it might affect the life of your battery.
There's really nothing substantial you can do other than changing the power adapter.
May 21, 2011 | Sony VAIO VGN-FW250J/H 16.4-Inch Laptop
The replacement battery -displays message
Unplug the power cord from the computer and remove the battery. Using a pencil eraser gently clean the contacts on the battery and computer. Check to see that the replacement battery is good.
Jul 17, 2010 | Sony VAIO VGN-NR285E/T Laptop
Baught a sony Vaio online but seller gave me the wrong personal password. I want to know if there is a way to bypass that? It is a Sony Vaio VGN-NR285E. Any Help will be greatly appreciated.
If it is a hard disk password, you will need to take it to a Sony repair shop or send it to Sony. If it is just a boot password, clearing the NVRAM should fix it.
Jul 03, 2009 | Sony Vaio PCG-FXA Series AMD (A8058677A)...
Vista vaio survey has stopped working
VAIO Update has been disabled. Start , all Programs, VAIO Update 3, VAIO Update Options , Reenable the checkboxes and you shouldn't get the message anymore. This program runs at startup to check for updates with SONY, pretty useless.
Feb 04, 2009 | Sony VAIO VGN-NR285E/S 15.4" Notebook PC...
Sony VAIO VGN-NR285E/T Laptop Logo
669 people viewed this question
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
