Question about Kenwood Multi Pro FP730 Food Processor
How do i use centrifugal juicer? - Kenwood Multi Pro FP730 Food Processor
Posted by Eddy Borgonje on
Lance Hill
    Genius:
  • 1,739 Answers
The Instruction Manual for the Kenwood FP730 Multipro Food Processor can be found online here:
http://www.kenwoodworld.com/Global/Instruction%20books%20(User%20manuals)/Food_Processors/57832%20Iss%203%20B5%20FP730%20English%20only.pdf
On page 7 you will find illustrated instructions for the assembly and operation of the centrifugal juicer.
Posted on Dec 03, 2011
Do you have ultimate chopper juicer jar
we do not have anything but advice to questions
contact the manufacturer or retailer of your machine and ask them
Aug 09, 2016 | Ultimate Chopper Food Processors
Instruction manual for Prinetti multi function food processor blender juicer
Hello, You will have go back to Prinetti, cust service to get the manual that you want.
May 16, 2014 | Food Processors
Where to find replacement parts for intertek 3181976
ONLY TO ASK WHERE CAN I FIND PARTS FOR THE juicers BRAND NINJA PRO SERIES 1100 GREETINGS FROM TIJUANA MEXICO.. THANKS
Jun 14, 2013 | Food Processors
Where can I get a manual for Wolfgang Puck 3 in 1 blender, food processor, juicer from HSN?
Wolfgang Puck Instruction Manuals are available here:
http://www.wpcookware.com/manuals.asp
If you do not see your model number for your product, suggest you contact their Customer service at 1-800-275-8273 to determine if the Instruction Manual for your model is available. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Nov 11, 2010 | Wolfgang Puck Food Processor
How to remove top cover moulinex masterchef a77
The Rubber cog unscrews anticlockwise to come off.
Sep 02, 2009 | Food Processors
How to attach grating/shredding blades to GE Food Centre FP22
When you remove the regular chopper blade, it should fit on top of the stem. The chopper blade must be removed to use the slicer / shredder attachments.
Jan 05, 2009 | GE Food Processor
Cusinart little pro plus
I have this food processorfor years and I love it. If you need a copy of the manual go to the Cuisinart website - they have all of the maunals listed there. But, here is the instructinos for the juicer. Good Luck. Using The Juicer
The Citrus Juicer
Attachment includes:
Strainer Basket, which
locks into processor work
bowl. It has grooved cam
on one side and smooth
locking device on opposite
side. In its center is the:
Juicer Stem Adapter,
which fits over motor shaft
of Pro Plus™.
Small cone, for lemons
and limes. It must always
be attached to Adapter
when Attachment is in use.
Slot in center of underside
fits rib on Adapter.
Medium cone, for oranges
and large cone, for grapefruits.
Both fit over small
cone.
1. Place work bowl on Pro
Plus™ base in usual way.
Hold Strainer Basket
open side up, with
locking device facing
you. Align locking device
slightly to left of locking
tab on front rim of work
bowl.
Place strainer basket on
work bowl, fitting Juicer
Stem Adapter loosely
over motor shaft. Turn
basket counterclockwise
as far as it will go, until it
clicks into position.
Turn Juicer Stem
Adapter clockwise until it
drops into position.
Check that it is down as
far as it will go on the
motor shaft.
2. Hold small cone by top
and place it over Juicer
Stem Adapter, fitting slot
over rib on adapter.
Cut citrus fruit in half and
hold cut side down over
cone. With other hand,
hold control lever in
PULSE position and
press down fruit to
extract juice. For continuous
operation, move
control lever to ON. Twist
fruit to extract most juice.
Do not allow juice to
overflow center tube of
work bowl.
To remove attachment,
remove cone from Juicer
Stem Adapter. Loosen
adapter from motor shaft
by lifting it slightly, straight
up. Hold Strainer Basket
on both sides and turn
clockwise to unlock it from
work bowl. Lift straight up.
Remove work bowl from
base and pour out juice.
Feb 03, 2008 | Cuisinart DLC-5 Food Processor
Kenwood Multi Pro FP730 Food Processor Logo
387 people viewed this question
Top Kenwood Food Processors Experts
Ross Keen
Andrew Taylor
Andrew Taylor
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
