Question about Marantz SR7005 Receiver
Upgrade id disappeared
After I upgraded my receiver with the latest firmware. I lost my upgrade_id. Because of this I couldn't get the airplay upgrade. Can someone please help me retrieve my lost upgrade_id?
Posted by Kin Fung on
    Top Expert:
  • Marantz Master
  • 76,785 Answers
Hello
All these details are in its repair book. There are so many adjustments should be done, and all are described in detail in that book. I've the book, but aI can't send it to you by this window as it does not allow ma to upload PDF files by it. If you come over me by purchasing any one among the audio services advertised at Fixya, I'll send you both the user manual and repair book to you by return mail. The repair book is very usefull to you as it contains all the internal circuit details, schematics, possible repair and its remedies. OK.
Posted on Jan 08, 2012
My psp always says the game could not be started (dadadada) how do I fix this?
DADADADA is an error code that dax made so that you couldn't upgrade to official firmware from custom firmware. If you want to get rid of your custom firmware, you have to recover back to 1.50 and then upgrade from there.
3helpful
2answers
Yamaha receiver will not connect to Airplay
I have the same problem, it seems the airplay connection is easily lost, it never plays for longer than an hour without itunes losing the receiver, then i have to reset the receiver so that it appears in itunes again, very annoying. I spoke to Yamaha and they are not aware of any issues but clearly there is one. A quick workaround is to bring the receiver up in a browser by typing in its IP address, go to IP Address tab and simply apply without changing anything, this causes the receiver to initialize its network function as you will see the amp resetting and it will then appear in iTunes. This doesn't work through the units setup without changing settings and then changing them back again. Hopefully this is just a glitch that will Yamaha will fix in the next firmware update, I am running 1.14 update.
Ciao i will buy a Technics SL-DZ1200 used I want to know if it's necessary to upgrade the firmware. Also, i want to know the latest release of the firmware in distribution Is The latest...
the firmware depends on display. if the display does not supports MP3, firmware upgrading will not help. most of the time upgrading firmware will not help playing MP3.
My hp color Laserjet cp3525dn displayed error 55.50. Resend upgrade.
I couldn't find an error code of 55.50 in the service manual.
All 55.xx errors are DC Controller problems.
I did find the message "resend upgrade".
That refers to a Firmware upgrade that didn't complete successfully.
If that's what happened in your case...restart the upgrade and keep away from the printer
until the upgrade finishes.
How to solve service error 49.00 in hp laserjet 2430dtn printer
49.XXXXX ERROR
A critical firmware error has occurred.
1. Press Cancel Job to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on again.
3. Go to http: www.hp.com/support/lj2410, www.hp.com/support/lj2420, or
www.hp.com/support/lj2430. Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the
one installed on the printer and the printer can receive a firmware update,
download the newer firmware upgrade. Not all printer models can
receive firmware upgrades.
4. Try printing a job from a different software program. If the job prints, go
back to the first program and try printing a different file. If the message
appears only with a certain software program or print job, contact the
software vendor for assistance.
1. After performing the actions listed in the preceding item, if the message
persists when using different software programs and attempting specific print
jobs, disconnect all cables that connect the printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs and thirdparty solutions from the printer.
4. Remove all of the EIO devices from the printer.
5. Turn the printer on.
6. If the error message disappears, reinstall each DIMM, Compact Flash card, and EIO device one at a time, making sure to turn the printer off and then on again (booting to the Ready
prompt) as you install each device. To replace a DIMM, see Appendix D - Printer memory and expansion in the LaserJet 2400 Series User Guide.
7. Replace the DIMM or EIO device that caused the error message.
8. Remember to reconnect all of the cables that connect the printer to the
network or computer.
9. If the error message persists, reinstall the firmware with the latest possible firmware upgrade. Go to http:www.hp.com/support/lj2410, www.hp.com/support/lj2420, or www.hp.com/support/lj2430. Click Download Drivers and Software.
Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the one installed on the printer and the printer can receive a firmware update,
download the newer firmware upgrade. Not all printer models can receive firmware upgrades.
10. Replace the formatter
I am using the airport express to play itunes through my stereo only. I unplugged the unit to move it to a more convenient place and now I cannot to get it to work. It was working well before. I...
From my reading at the Apple support web site, it appears that you may need to download the latest version of the Airport Utility in order to get around this issue.
Additionally, Apple has just recently come up with an update to the firmware for this device.
Try downloading the latest version of the Airport Utility (Mac or Windows) and see if that doesn't resolve the issue.
After installing the latest version of the Airport Utility, try to connect to the Airport Express. If that is successful with the new version, click the "Manual Setup" button to display the "Summary" page for the Airport Express.
Next to the entry for "Version:" there should be a button to press to upgrade the firmware to the latest version (7.5.2). Perform the upgrade by following the on screen directions.
After the upgrade, again attempt to connect to the Airport Express using the Airport Utility. This should work as expected.
Before attempting to use the AirTunes (recently renamed "AirPlay"), make sure that you have the latest version of iTunes installed.
Was stuck on initializing now no power at all
RCA Opal 4001/4002 – Restoring the Player
Download the latest firmware upgrade from www.rcaopal.com to restore the player. The firmware upgrade file will be on the "Download Upgrades" section of the website.
-Tha Mp3 Doctor
3helpful
Hp 2420 service code 49 2F90 what does it mean?
support/lj2420, or
Software
. Check for the
upgrades.
Failing that replace the formatter
Firmware Upgrade
Where did you get the firmware upgrade? Please provide link.
Open Questions:
See all Marantz SR7005 Receiver Questions
Marantz SR7005 Receiver Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
