I've had this same problem since the day I bought this printer a year ago. I'm trying to print labels for my homemade bath products on a thick waterproof paper specially made for laser color printers. I've changed the waste toner and the drum, but I have hardly used this printer enough to change out the colors. When I'm ready to print my labels, I select "thick paper" or "thicker paper" and it has not made a difference. There are 6 labels on a paper. The top 2 have a little bit of a messup on the bottom of it and the last 4 are just totally messed up. It looks like the colors are being realigned while it's printing...I'm not sure how to word it. Here's what I'm talking about: http://i1237.photobucket.com/albums/ff468/approvedent/IMAG0326.jpg
SOURCE: HP 8500 Color Laser Printer- problem priting reds
the basic causes for this problem is either the foil is bad or weak. secondly the element in the fuser unit doesnt heat properly so try replacing it with a working one n see what happends.
SOURCE: Difference between Brother HL-4040CN and HL-4050CDN printer
The D stands for duplex printing (both sides of paper)
SOURCE: HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Rgds
S88
SOURCE: HP color laser 2550l prints only yellow
Are you sure that none of the other colours are empty? If they are then this could be the problem
I forgot to mention that it prints perfectly on regular paper, but this printer should be able to print on this kind of paper since the paper is made specifically for laser color printers.
light installation and reflector? Where are they located? No, I haven't changed them recently. I've only had the printer a yr and hardly use it.
