SOURCE: SYLVANIA SRCD227 REMOTE CODE
First tell me what brand tv and date of mfg & model# maybe I can help. Chuck [email protected]
SOURCE: Sylvania LC155SC8 remote TV code for Verizon Fios
buy the radio shack "6 in 1 remote. It has a "learning" mode that picked up all my needed commands from both my verizon fios remote and my new sylvania hdtv remote. works perfectly.
SOURCE: philips universal remote - tv codes for Sylvania
Only one code worked (out of the 13 codes provided for Sylvania TVs
with my Philips Universal Remote) so I could program my Philips
Universal Remote to operate my Sylvania 6413TC 13" TV: 0520
After manually turning on the TV:
1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
2. Press and release the desired Mode button (in your case -
TV). The red indicator blinks (very quickly), then stays lit.
3. Enter the 4-digit code (0520), and if it's valid, the red
indicator should turn off. (Supposedly, for an invalid code, the
red indicator flashes. However, when I tried all 13 codes, the
red indicator turned off, yet only one code actually worked. Go
figure.)
4. Press CHANNEL UP. If your TV responds, no further
programming is required. Although, some buttons on your Universal
Remote may not operate your TV. (They all worked for me, yeah!)
If 0520 does not work for you, here are all the codes provided by
Philips: 0807, 0002, 0502, 0115, 0520, 0919, 0324, 0247, 0402,
0408, 0109, 0715, 0717.
SOURCE: Sylvania LD320SS8 HDTV Can not program COMCAST Remote Control.
try the various codes listed for phillips. that should cure your problem. if not try sampo.
Code is0189 for sylvania 6842pem found it on my universal remote code sheet hope this helps
